okay 9 flashes on a kymco means means the scooter in freewheel, move the freewheel lever, if that doesn't sort it check the little microswich located on the brake on the end of the motor , it common for them to fail, the scooter is saying it can't see the resistance of the brake ..okay 9 flashes on a kymco means means the scooter in freewheel, move the freewheel lever, if that doesn't sort it check the little microswich located on the brake on the end of the motor , it common for them to fail, the scooter is saying it can't see the resistance of the brake ..
Paul, you mean the the invacare lynx ? , two flashes can mean a bad connection to the motor, simply remove the axle and refit ...Paul, you mean the the invacare lynx ? , two flashes can mean a bad connection to the motor, simply remove the axle and refit ...
You can't post conmments that contain an email address.
So I jave a voyager rover and keep seeing E 10 on LCD screen and idk what it means on it?So I jave a voyager rover and keep seeing E 10 on LCD screen and idk what it means on it?
The drive lever on a Kymco mobility scooter is the lever that engages the motor and allows the scooter to move forward or backward. It is usually located on the handlebars of the scooter and can be controlled by the user. If the drive lever is not engaged properly, the scooter may not function correctly and could result in the flashing 7 times error code. You should consult your user manual or a certified Kymco dealer for more information on how to engage the drive lever correctly.
In the context of a Kymco mobility scooter, the drive lever is the lever or handle that engages the motor and allows the scooter to move forward or backward. The drive lever is typically located on the handlebars of the scooter and is used to control the speed and direction of the scooter.
If your Kymco scooter is flashing 7 times, it could indicate that the drive lever is not engaged properly. This means that the motor may not be receiving the necessary signal to start or operate the scooter. To resolve this issue, you should check that the drive lever is in the correct position and fully engaged. You may also want to check the wiring and connections to ensure that there are no loose or damaged wires that could be causing the problem. If you are not familiar with the mechanics of your Kymco scooter, it may be best to consult a certified technician to help diagnose and fix the issue.
Question edited to reflect that you fixed it. Well done.
Just an update all fixed. Check your pins in the brake motor connector. I snapped the pin while sorting it out so redid that and now all working again thanks.
hi Graham, okay assuming it got a PG Drive controller or a ds 90 dynamic controller fitted , 9 flashes means a internal fault ,,,check all of the connections to the controller including the brake and motor connection.. it 's can be a real frustrating fault..For example i had scooters working perfectly then one day 9 bleeps, after making sure of connections were good ,it worked once again..
Currently i 'm working on a ds 90 dynamic controller , it got a 9 bleep problem, dry joints on the controller board ...
9-flash usually indicates a blown controller. The larger pride scooters are known for blowing controllers and having melt-downs when they are pushed or towed too fast. EVEN WITH THE KEY OFF the controller still monitors the safety systems. If the system detects a "roll-away" situation, the controllers turn on and go into dynamic braking mode in attempt to slow or stop the scooter. If the scooter is being towed or pushed and this happens, the scooter tries to stop the motion, overheats and burns up. Catastrophic failure and 9-flashes will result.
Best regards
Can anyone tell me what error code 2 is on a Lyn or maxer mobility scooter
