I put in a new spark plug and still does not start. I think it might be dirty gas or plugged fuel line???I put in a new spark plug and still does not start. I think it might be dirty gas or plugged fuel line???
If you filled the fuel tank with gasoline enhanced with ethanol the fuel may be bad and caused the carburetor to gum up. Also Honda engines have a low oil sensor and from your description of the oil, can cause problems with the sensor and the engine won't start. Try changing the oil first and then adding a small engine gasoline additive that helps with stale gasoline starting problems.
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
This problem may have many reason but you can try one of the solutions, when suddenly engine stops and kick rod is going smooth without resistance try push and start by directly in 2nd gear or 1st gear and after it starts keep the engine running by giving small revs for a min....
FIRST ORDER PROPER RINGS UTILIZING ENGINE SERIAL NUMBER LOCATED ON SIDE LOOKS LIKE GCAT-1919182 THEN GET THEM STANDARD REMOVE CYLINDER HEAD AND FRONT COVER REMOVE CONNECTING ROD BOLTS PUSH PISTON THROUGH INSTALL RINGS IN SAME ORDER WITH LETTER LOCATED AT END OF RINGS UP WITH GAPS WITH GAPS AT 90 DEGREES APART REINSTALL USING RING COMPRESSOR HEAD GASKET REPLACEMENT RECOMMENDED.
Parts are easy to find for honda engines at the small engine shop and on the net. All that you need do is to locate the model and spec number of the engine itself and go to the link below for your parts. Some honda parts are available in assemblies only, like the complete starter. Be sure to check ebay for aftermarket parts. You may save some money. Look for a "starter pawl assembly kit" .
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
BEFORE you go thru all of the advice and look at most other Honda web
info.....go and buy a brand new spark plug and start with that! It
appears Honda used a NGK spark plug in the past that fails after some
time....giving the syptoms of problems with the carb, sticky valve, etc.
Do not try to clean and use the old spark plug!!
Check this out....it was the answer I was looking for after hours of
work, reading, and talking to Honda dealers ----
http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
have you started the engine before this problem ?
