Anyway to fix the 1500 Vostro with flashing A and no display
SOURCE: Turn on my Dell Vostro 1500 and all I get is a black screen
Remove and re-seat your RAM cards. Remove your battery but leave the power supply attached. Try to start. If this doesn't work, your motherboard has died and needs to be replaced. Not a do-it-yourself job unfortunately.
SOURCE: Vostro 1500 screen blank except for flashing cursor
The good news is that your laptop powers on and you have a display. The bad news is that you laptop is trying to boot up from an OS (operating system software) like XP, Vista, or Win 7. Ether your software is corrupted or you have a problem with the hard drive or hard drive controller.
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed under the "Contents". You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the "One time boot menu". Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the "Run the 32 Bit Dell Diagnostics".
If diagnostics pass then your software is corrupted and needs to be reinstalled.
