Covering everything from ultrabooks to servers from Windows 8 to virtualization PCWorld delivers the information and expert advice you need to get the job done
What kind of memory card are you talking about? If it's one of those cards from a camera, PDA, etc, it should be on the front of the computer, if you purchased that option. The normal XPS 400 does not have a memory card reader.
1. Your camera probably came with a USB cable. If so you need to connect that cable from your camera to your PC and turn on the camera. Your computer should automatically recognize that you've plugged it in and should run a "wizard" that will walk you through importing those photos.
2. Your PC may have a "multi-card reader" this is a series of slots that accept different sizes/types of memory cards from cameras etc. Your camera has a memory card that you can remove and place into one of these slots. Again once you've plugged in this memory card you should again get the wizard asking you'd like to do.
ok add me to messenger, there is a HDSD card .cab file you must install on the device for it to accept HDSD..
instead of searching, i can just send it to you.lol
active sync problem..
uninstall, restart pc, install, restart c. done if no. . hard reset p3300
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
