20 Most Recent Dell XPS M1210 Notebook Questions & Answers
2answers
Dell 210 xps dislays ! ! 0xc0000034 ! ! 271/100931
This error is a registry error and it is with Windows 7 I presume.This will take a Windows Tech at Microsoft to get a solution. The registry is not to be tampered with unless you a very learned in this area.I don't recommend giving instruction to anyone who is not familar with the registry.My recommendation is to call Microsofts tech support.It looks as though the mail file for the SP1 file is corrupt and will not load the dynamc link library for the Outlook or Outlook expess ( SP1 = Service Pack 1)
2/24/2016 7:11:05 AM • Dell XPS M1210... • Answered on Feb 24, 2016
5answers
DRIVERS FOR DELL XPS M1210
you need the ricoh chipset drivers
2/4/2015 3:41:42 PM • Dell XPS M1210... • Answered on Feb 04, 2015
0answers
All apps are on my Dell xps but I can not get into the apps, what do I do
it depends on the operating system, you might have to use the program search box to find them, you might have a virus, sometimes you run into a virus that hides everything on your computer, that what most viruses did back in the 90's before the internet became accessible to everyone
1/28/2014 1:07:28 AM • Dell XPS M1210... • Answered on Jan 28, 2014
My CD drive reads all CD and DVD but not able to w...
you used nero or other write program ? some times are the software but other times be the lector try change it to see if the failure still exist
1/22/2014 5:03:27 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Hi Sir or Madam, My name is Michael. I have De...
the indicators leds are on or off mode ? if are turn off with the power mode maybe have a problem in the main bord or the battery charge it again and try
1/22/2014 5:01:35 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Hi I have a Dell xps M1210 notebook the screen
the problem you video chip is work of try soldering it with a rebaldiung calor and ready it works again it hapened wen you install a windows version with 64 bits aceleration change all it and you noteboock are work again fine vote please
1/22/2014 4:59:32 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Hi I just purchased a new screen back cover for my
replace with the same number couse some came in lcd and the news come in led but some come left side and others rigth side te conector this is the problem check the number of sceen ans then change it for the remplace or original
1/22/2014 4:56:29 PM • Dell XPS M1210... • Answered on Jan 22, 2014
I have a dell xps
first wen the prompt apaer in the screen push many times key F12 then the prompt mode is say to you if you want to begin start in hdd or dvd or usb or net you chost dvd or cd boot and ready vote please
1/22/2014 4:52:00 PM • Dell XPS M1210... • Answered on Jan 22, 2014
My dell's (xps m1210) wireless switch has been
remove all the bottom screws and open the notebook then change it plastiv part and ready or check the sw push and put ir in on and put the cover tap again and ready
1/22/2014 4:49:33 PM • Dell XPS M1210... • Answered on Jan 22, 2014
How can i change the
akip all the screews then cover down open here in rigth side see the batery disconect it for a few seconds and then put ir again and ready some times only with the tap of the memory can see it battery remplace it too
1/22/2014 4:46:57 PM • Dell XPS M1210... • Answered on Jan 22, 2014
My compter keeps saying bad video card
Change the video drivers this is the problem
1/22/2014 4:44:18 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Laptop screen black plugged in
Change the hv volt in to the lamps in the screen inside call inverter this is all you problem vote please
1/22/2014 4:43:41 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Windows xp not connecting to internet
Chek first the network status in control panel this go to have clear numbers in to the protocol ip adreess just like it 0.0.0.0. but if this is clear go to my PC and in to the direcction of my pc put it www.homepage.com and if this work try install exeplorer again or googlechrome
1/22/2014 4:41:41 PM • Dell XPS M1210... • Answered on Jan 22, 2014
How do I get out of SAFE MODE???
wen you lap is gone prompt push many times key F8 and then give you the options to go at safe mode or normal mode
1/22/2014 4:38:26 PM • Dell XPS M1210... • Answered on Jan 22, 2014
My wireless on my m1210 not working
First chek the network status check the ip adreess is clear 0.0.0.0. and then try again if the network ip have some numbers 198.254.0.1 etc your wirles never gona work try it first
1/22/2014 4:36:54 PM • Dell XPS M1210... • Answered on Jan 22, 2014
My dell m1210 keys beep but don't type how do I fix this
chek the good conect it in to the main bord two if it well conect disconect it and try with a usb external keyboard to descart fail in to the main bord if it is work fine change you keywoard rempace it
1/22/2014 4:34:48 PM • Dell XPS M1210... • Answered on Jan 22, 2014
My wireless adapter cannot see any wireless networks in range
you have a problem with the range or apear one indicator network work of ? if is the first maybe the ip adrees is corrupt in you mac conections or if not apear any your airport mac adaptor is work out change it vote plase
1/22/2014 4:32:15 PM • Dell XPS M1210... • Answered on Jan 22, 2014
I want to connect pc suite for nokia through bluetooth
if you laptop not have a bluetooth adapter buy one compatible usb bluetooth and ready can you conect all bluetooth diveces please vote
1/22/2014 4:29:33 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Edit Bios System Data
To begin go to mode safe start then in to the add and put programs clear all video contolers and then restart the lap then it go to begin normal but in the start it want the video driver put the default and ask the real video driver of this but you machine is got to work again nomaly witout vifeo drivers please vote
1/22/2014 4:27:16 PM • Dell XPS M1210... • Answered on Jan 22, 2014
Dell XPS M1210 Notebook Logo
200 questions posted
Popular Products
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
XPS Dell
  • XPS Dell
Most Popular Question
remove repair partitions dell laptop
  • Computers & Internet
