New World G70m Gas Double Oven Logo
Posted on Jun 21, 2009
Oven doesnt work
Our G70m cooker isn't working, when we turn the oven on it wirks for 5 mins then it turns off by its self.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jun 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2831
Points
9
You have a short most likely try to unplug for about two mins to let reset
What door seal fits a newworld g70m vision double oven
https://www.ransomspares.co.uk/parts/cookers-hobs/universal-oven-door-seal-4-sided/121113.htm
Feb 18, 2020 • Ovens
Ignition not working although there is power to the cooker (oven fan working)
we turned it off at the plug left it for a 5 minutes it then worked again
Mad gas flame at back of New World G70M
HI it could be agas pressure problem meter pressure too high get the gas company to check it out for you
Oven shuts off when the door opens
Turn breaker off for 5 mins. then turn back on, this will clear the memery and take it out of self clean.
Please rate solution
1helpful
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
What type of gas?
Only if you fit the correct jets to the burners.They usually come with the oven
2helpful
2answers
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 • Ovens
New World G70m Gas Double Oven switches it self off and then when cooler switches it self back on and also clock resets at zero. Any ideas please.
Was sorted out with insurance from New World and it turned out to be a circuit board and all knobs replaced. You can get circuit board on ebay for about £38.00 plus postage if you are capable of fixing it yourself.
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 • Ovens
Top New World Ovens Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a New World Oven Expert? Answer questions, earn points and help others
