I have labtec lcs-3210 but no wires, power jack says DC 15V but what amp do i need? also can i use any male to male 3.5mm headphone wire to connect the left and right speakers?
Look on the back of the speakers there shoud be a tag and on the tag should be the amp rating. but this should answer your question. www.jdr.com/PDF/currentspec/lcs-3210.pdf -
On a desktop you plug them into a jack located on your sound card (varies by card model) . Laptops use the headphone jack to connect external speakers.
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
your speakers should have a headphone jack, and your computer should have a speaker-in jack and a mic-in jack. plug your speaker jack into the jack on pc
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
I have the same problem sir, only the speaker with volume control works. Earlier I used to twist the volume control this way and that way to get the sound from the other speaker also. Now the same technique doesn't work anymore.
1 wire goes between the 2 speakers 1 wire goes from the speaker with 2 jacks in it to the computer, the back of the computer should have a green port to plug in the cable to 1 wire is the power
