2005 Chrysler 300 Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Gray/Light Green Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power. Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Gray/Violet Left Front Speaker Negative Wire (-): Gray/Yellow Right Front Speaker Positive Wire (+): Dark Green/Violet Right Front Speaker Negative Wire (-): Dark Green/Yellow Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Dark Green/Tan Left Rear Speaker Negative Wire (-): Dark Green/Gray Right Rear Speaker Positive Wire (+): Dark Green/Brown Right Rear Speaker Negative Wire (-): Yellow/Green
2006 Toyota Corolla Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Blue/White Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: White/Black Car Stereo Antenna Trigger Wire: Black Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Violet Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Blue Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
This should be all you need, enjoy the tunes!
1998 Lincoln Continental Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
Here is your stereo wiring 1989 Ford Thunderbird Car Stereo Wiring Diagram
Radio Battery Constant 12v+ Wire: Green/Yellow Radio Accessory Switched 12v+ Wire: Yellow/Black Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Blue/Red Stereo Dimmer Wire: N/A Stereo Antenna Trigger Wire: Orange/Blue Stereo Amp Trigger Wire: N/A Stereo Amplifier Location: N/A Audio Front Speakers Size: 5′ x 7′ Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Black/White Right Front Speaker Positive Wire (+): White/Green Right Front Speaker Negative Wire (-): Black/White Audio Rear Speakers Size: 5′ x 7′ Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Pink/Green Left Rear Speaker Negative Wire (-): Pink/Blue Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Green/Orange
Here are the wiring colors but just before you connect it please make sure the colors match 1999 Daewoo Lanos Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Dark Green
Left Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Negative Wire (-): Gray
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue/Black
Right Rear Speaker Negative Wire (-): Yellow/Dark Green
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Orange Car Stereo Dimmer Wire: Black/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
whoop! there it is! 1994 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
window.google_render_ad();
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black Car Radio Accessory Switched 12v+ Wire: Black/Pink Car Radio Ground Wire: Black/Green Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Blue/White Right Front Speaker Positive Wire (+): Tan/Green Right Front Speaker Negative Wire (-): Green/Orange Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Blue Left Rear Speaker Negative Wire (-): Brown/Yellow Right Rear Speaker Positive Wire (+): Black/Violet Right Rear Speaker Negative Wire (-): Orange/Violet
