When i push forward it goes in reverse. & when i pushreverse it stops
SOURCE: When turning the scooter on the system goes by
Sounds like the throttle mech has come loose, the lever is normally fixed to a pot with a long stem now if that's moved round it will power it self without any movement?
SOURCE: goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
SOURCE: Same problem
If your batteries have ever gone dead, they can show fully charged, then completly discharge very rapidly. Take them to autozone and ask for a "load test". If they don't hold a load, replacement is nessary. [email protected] for more if the batteries pass load test
Testimonial: "It was the batteries - they needed replacement. Thanks to all who responded!"
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
SOURCE: my scooter when I press the throttle to go forward
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
