The buzzing only happens when the dryer is heating/ gas is lit and heating. Buzzing is constant until heating cycle stops. No other problems but quite annoying, I'd like to find the buzzer and unplug it.
I know this is old, but I just got this problem fixed and would like to help other people with this issue. It's the gas valve coils (solenoids). They're faulty, and mine came that way... I lived with that horrible sound for years. I was out of warranty but called Samsung to figure out the problem. They said it was "normal operation" which was total BS. When the coil clicked on, it rattled and buzzed super loud. Had a repair guy come. Samsung charges 200$+ for the replacement gas valve coils. However, my repair guy found that the part that came with the dryer was actually made by Maytag!! They swapped out the faulty Maytag coils with a working part and the buzzing has stopped. Hope this helps. Amazon com Samsung Dryer Gas Valve DC62 00201A Home Improvement
http://www.appliancepartspros.com/samsung-valve-dc62-00201a-ap4203162.html
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
SOURCE: Repairing Frigidaire FER641FS0 Electric Dryer
I would suspect the drum belt has broken.
Reply back what you find and I will help you further.
SOURCE: dryer heats, then quits
The thermostat that controls the heat has failed. Try one of the other settings on the timer switch ans see if it will heat, the different cycles use different thermostats.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
