Kenwood KDC-MP4028 CD Player Logo
A
Anonymous Posted on Apr 23, 2014
Cd will not stop reading
I put in a cd and it just keeps reading
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Sanyo dc-da2000 cd player starts spinning then stops
if the display on the CD, reads, no disc, then try to clean the CD lensthe best way is with a cotton bud and white spirit or something similar also buy a cheap CD lens clearer kit, in the cheap shops for about a quid, keep putting it into the CD player, it will clean as it goes,
I have a denon DCD-625 and it has suddenly stopped reading some CD's. Even a new box set I got for Xmas - reads 1st one but not other two.
Maybe it is dirty. try a cd lens cleaner. you can get them from local electronic stores. and if that's the problem then keep your cds clean. put them back in their case and only handle them by putting your finger through the hole and gently supporting the outside edge. never touch the face (other side to label) and if you do get dirt or bogies on em then clean from the center outwards in straight line. Good luck!
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
2answers
Error 03-EEEE-0000
try to clean the CD drive. it is having problem reading any of CD that you put in. you may have use the CD cleaner few time. RadoShark, Best buy they all have the CD cleaner.
Cd-rom drive
Hey Dale,
It sounds like there is an issue with the laser in the CD-ROM drive because it spins for 10 seconds trying to read the disk and stops because it cannot. If you try and put another disk in and it does this then the CD-ROM is bad. You can find replacements online for reasonable prices. You can also go to most electronic stores to purchase a replacement. They usually run around $30 dollars or less.
Thanks - Tech101
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
