20 Most Recent
IBM ThinkPad 600 E Notebook Questions & Answers
Wont play dvds
Try loading DVD decodeing softawre, windows media player rarely plays DVD's without help from other decoding software. Use this link, download, and try this. Then let me know.
Forgotten password cannot logon to window
it is really very easy to reset passwords for windows, but if you don't know what you are doing you might end up with only one solution and it is to reformat and re install windows!
Turning on a wireless switch
it says this when it do not have a driver for it ..or if it is not turned on from the button ...take a look on the devices buttons..sometime they are on a side of the laptop..or in front ...and it has a symbol on ...with the wireless..
I can't get my speakers to work. I have to use
Hmm, sounds like either the speaker/speaker cable/speaker connector) developed a problem (not very likely as the parts are rather solid) or the headphone socket connector is damaged or is beginning to lose contact with the motherboard. If it's just a matter of the socket desoldering itself from the motherboard then the solution is relatively easy - you need to re-solder the socket. This involves stripping the laptop as you would need to get to the bottom of the motherboard. 600E is relatively easy to dismantle (most thinkpads are :)
Also, the headphone socket has small "switch" where if a headphone jack is inserted, it disconnects the internal speakers. In some cases the "switch" gets stuck in that position and you end up with speakers disconnected regardless of whether the jack is in or not. In any case, it's a pain to fix and involves either replacing the socket or stripping the socket.
Well-good luck :)
Hope this helps.
Raf
Everytime i boot up dos
It's asking you to go to set up to enter the correct time in the BIOS also when rebooted make sure your time zone is set correctly
EO 301
First u check the RAM capacity.If u have Windows Vista operating system then Minimum 1GB RAM put it.
OR
Goto start-programs-Accesories-System Tools-Disk Defragmentation.There u select the drive and press Defragment Button.After all drive defragmentation,u restart the laptop.
CMOS
Complementary Metal Oxide Semiconductor (BIOS)
CMOS setup is the settings, for the motherboard, you get into before the PC boots into windows.
Usually by pressing F1, F2, or Delete during system startup.
Battery Life
As long as the battery is working properly it doesn't need to be changed. Laptop batteries are like any battery the more you use them the faster they wear out. If available you should always use the power supply.
Error 161 and 163
any error like this is a dead giveaway youre cmos is dead.
Its a really common problem.
Dead
when replacing ram or hdd we
need to remove battery first, check by installing old ram.
IBM Thinkpad 600E 2645 not boots
Format the harddrive and install an Operating System of your choice.
Good Luck.
PS: You can probably disable that memory check in your BIOS to speed up your boot time as it is not necessary.
