Needle with long thread don't break thread but comes unthreaded how can needle come unthreaded without breaking thread
SOURCE: The serger is not sewing
The machine was threaded incorrectly at first, but after changing the needle I was threading it correctly. The problem ended up being the needle depth. When I inserted the new needle, I did not have pushed up into it's slot quite far enough. I pushed it up all the way and retightened the screw. Now it is serging like a dream!
SOURCE: The needle thread is blocked
Threading instructions for similar brother model:
http://www.mastersewusa.com/masmag11901_files/b114_471_721_771_XL711S_info_tg.htm
Possibly lever is to keep bobbin in place? If so, should slide left/right over top of bobbin.
SOURCE: We have a Delta sewing machine.With luck it may
the problem of your machine is the bobbin. fix it in her right position.
SOURCE: my needle keeps coming unthreaded when sewing
normally when you use longer thread tails of 4 to 6 inches and move
the thread tails behind the needle before starting to sew.
