SOURCE: Not able to configure wifi router
im having trouble with wireless connection it says i have full signal but is not connected
SOURCE: I have a Tata Wimax
Ok...don't panic....take it all back out thru control panel>add/remove...reset your wimax modem by the little reset hole in the back as this can be an issue sometimes by adding the modem in the incorrect order. You should install everything but the "lan" cord from modem to modem last. A good test is to take the "lan" cord from your winmax modem and plug it right into your pc and you should have internet.
