My razor has two batteries. Some vendors are offering a single battery for replacement. Will a single battery work?
SOURCE: how do you replace the battery on a 800rx my shaver dosnt work
You will need to remove the 4 screws on the back to remove the back case. Once removed, you will see the batteries. There are metal tabs on the batteries that connect them to the circuit board. I suggest cutting these tbs close to the batteries. You can then solder your new batteries to those tabs that are still connected to the circuit board.
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-select-norelco-remington-p-214.html
SOURCE: MY RAZOR BATTERY NO LONGER HOLD A FULL CHARGE. ARE
mcdevito75 here, Some Norelco batteries can be changed and others not, it depends on the model you have, Online Norelco shavers.com
