20 Most Recent Norelco Bodygroom Men's Total Body Grooming System Questions & Answers
8answers
I have a Norelco,Body Groom.
OK, I am incredibly impatient, so I just figured out how to disassemble the bodygroom on my own. The button issue is fixed quite easily as there is no spring.
To disassemble, I simply removed the silver/gray side plates. Then put an instrument in the blue hole and torqued it a bit and the fittings popped out of place and the top released. I recommend using some sort of plastic tool so as not to mar up the casing. Then, the guts are fairly straightforward. The button is just a piece of rubber with a rubber knob on the bottom. When you push it, it simply pushes a really small button on the motor. When it gets stuck, I am guessing the rubber knob has somehow gotten stuck next to the motor button. After you take off the top cover of the motor, the button should be back to where it is supposed to be. Just put everything back together in reverse order.
That fixed mine! Good luck!
3/10/2014 12:41:31 PM • Norelco... • Answered on Mar 10, 2014
0answers
0answers
Disassemble tt2040
Be the first to answer 11/24/2013 3:01:04 AM • Norelco... • Posted on Nov 24, 2013Be the first to answer
I had a Bodygroom and
Same thing happened to me so I took the thing apart and that's all it took. The compartment that contains the battery and chip had a vacuum built up that prevented the button from being depressed. Once I opened it and released the pressure the switch worked again.
7/5/2013 6:50:20 PM • Norelco... • Answered on Jul 05, 2013
3answers
The Philips Norelco Bodygroom BG2040, does this
Welcome to Fixya,
According to the manual of The Philips Norelco Bodygroom BG2040, use only the cord and charging stand that was provided. Also you just have to plug the adaptor into 120V AC outlet.
If you want to know more about your Philips Norelco Bodygroom BG2040, just click here for the manual.
Hope this will help you and answered your question.
Thank you for using Fixya.
12/25/2012 6:55:55 AM • Norelco... • Answered on Dec 25, 2012
0answers
0answers
Hurts when shaving facial hair like its pulling it
Check the shaver head for damage. Most likely, there is damage to the thin foil. If so, you will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/grooming/norelco-philips-bodygroom-screen-and-cutter-for-bg2020-p-254.html
1/12/2011 3:35:20 AM • Norelco... • Answered on Jan 12, 2011
Finding a new head at
You will find replacement screen and cuter cartridge at shaveroutlet.com. see link below
11/4/2010 4:24:20 AM • Norelco... • Answered on Nov 04, 2010
0answers
The screen over the blade head is damaged where do
Hi, Not sure if you've got the BG2020 model, but you can try the folks at electricshaver.com and see if the have a replacement in stock. Here's a link with the foil/screens for Norelco shavers shown, I believe that your's is at the bottom of the page listing.
http://www.electricshaverstore.com/get_list_143.htm
If you want to talk with them directly, give them a call at 1-888-476-1785 and proivde them with the model number of your particular shaver and they can get you the correct parts.
Hope you find this Very Helpful and best regards!
10/23/2009 6:03:15 PM • Norelco... • Answered on Oct 23, 2009
Norelco body groomer
I contacted norelco and they said I need to buy a new head every six months. Nice. They will send me one free. As I said to them, I doubt if I would sustain that buying habit.
2/18/2009 3:54:36 AM • Norelco... • Answered on Feb 18, 2009
I'm looking for replacement heads for my 45 to 60 year old Norelco Electric Razor type HP1122. Can they be replaced?
Question edited for clarity. Two questions merged to one. Duplicate question deleted, refresh page to see your question. some Norelco spares are available https://www.google.com/search?q=replacement+heads+for+my+old+Norelco+Electric+Razor+type+HP1122 ..
12/3/2023 7:14:30 AM • Norelco Health &... • Answered on Dec 03, 2023
Can I purchase replacement heads for my old Norelco razor type HP1122?
I see some that are offered on E Bay https://www.ebay.com/itm/404374101537?chn=ps
12/2/2023 6:11:40 PM • Norelco Health &... • Answered on Dec 02, 2023
My Phillips Norelco NT8110/60 NoseTrimmer 1100 does not turn on even new batteries
It is possible that your shaver does not turn on or move because it is dirty. There can be hair or dirt particles stuck inside it, causing the shaving heads to be blocked. To fix this problem, properly clean your shaver. If possible, remove the shaving head and clean your shaver from the inside as well.
10/25/2022 3:03:22 PM • Norelco Health &... • Answered on Oct 25, 2022
Norelco Bodygroom Men's Total Body Grooming System Logo
Popular Tags
22 questions posted
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Norelco Health & Beauty
Most Popular Question
norelco body groom
  • Health & Beauty
