I want to lower the temperature on my cooler to make it colder. there is no control knob or digital control. The digital pad on the bottom only goes from USE to PAS.
SOURCE: refrigerator and freezer temperature control
Keep pushing the temp buttons, they'll cycle through to as low as it will go, back to the highest temp setting. From 2 repair bills I've had, suggest you leave them on the factory defaults. Simply unplugging for a minute, then plugging back up should restore to factory setting.
SOURCE: Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
SOURCE: temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
SOURCE: My refrigerator temperator does not seem to be
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
