20 Most Recent True GDM-33-SSL-54 Refrigerator Questions & Answers
True GDM-33 refrigerator icing up around the condenser then defrosts leaking water all over the floor.
It could possibly be an issue with the thermostat not shutting off. I would set it at it's setting to see if it shuts off. If not replace the thermostat. Also check to see if the evaporator fans are running.
11/3/2017 12:04:39 PM • True... • Answered on Nov 03, 2017
0answers
My evap pan keeps overflowing
The pan in the inside of the unit or the one underneath for collecting and evaporating the water?If it's the one inside take the front bottom panel off and blow out the drain line leading down there. If its the pan underneath and it cant keep up with the water flow check to be sure it has some white cotton looking panels in the pan. They are an accessory called a wicking kit designed to absorb the water and as the air blows over them they help evaporate the water. If those are present and in good shape but its overflowing there you may need to get an electric condensate pan.
10/24/2013 12:24:50 PM • True... • Answered on Oct 24, 2013
The cooler stays at 20 degrees. i have the
Change the temperature control.
http://www.acmehowto.com/howto/appliance/refrigerator/repair/tempcontrol.php
1/13/2011 7:54:10 PM • True... • Answered on Jan 13, 2011
Hey, it's only cooling to 50 degree and there is
Hello and Welcome to FixYa!
The Poor cooling that you are facing is caused due to the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing/opening the panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer that is exactly the thing you quoted. Such a frost build-up usually shows a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed/designed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer, The defrost thermostat (usually a bi-metallic switch), The defrost heater. Also you need to clean the dust, lint from the condenser unit by using a condenser brush or a vacuum cleaner to remove all the dust from the unit (it is usually located at the back of the refrigerator). If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. If the problem still persists and the above quoted techniques/tips didn't work,You may need a qualified appliance repair technician to further diagnose the problem.
Best of Luck,
Concerned.
9/17/2010 9:25:54 PM • True... • Answered on Sep 17, 2010
There is snow on the
The drain line is mostly likely clogged.
You need to find the drain line and try snaking the line out with either compressed air or a fairly sturdy length of wire.
Taking the face of the evaporator fan off would probably help with finding the drain. Unplug the fridge while doing this so you arent working around live fans or the defroster!
Good luck and be careful.
8/3/2010 8:05:08 PM • True... • Answered on Aug 03, 2010
Where is/are the ballast located for the two
http://www.truemfg.com/pdf/InstallManuals/GDM-3/gdm-3_english.pdf
7/25/2010 2:06:08 AM • True... • Answered on Jul 25, 2010
Evap is froze up is there a defrost cycle trueGDM -33
Probably the evaporator fan has stopped working. If there is no airflow evap will freeze. Chrck operation of fam motor.
4/18/2010 6:52:08 PM • True... • Answered on Apr 18, 2010
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
9/23/2009 3:44:53 AM • True... • Answered on Sep 23, 2009
True gdm-33 icing up have to disconnect then works
2 things to check - Excessive moisture coming inside will cause frosting - Have it serviced and check proper door seals - the next thing to check, for frost free units, is the defrost timer and its components - no defrost cycle = frosting up.
8/24/2009 6:46:12 PM • True... • Answered on Aug 24, 2009
True GDM-35EM - 39.5" Glass Door Reach In Refrigerator. I need copy of wiring diagram for a True GDM-35EM please.
Question edited for clarity. The Service Manual says that the wiring diagram is hidden in various parts of the unit. https://www.manualslib.com/manual/1177583/True-Gdm-Series.html?page=43&term=wiring+diagram&selected=1#manual It doesn't appear to be all in one place, but you could contact their Customer Service, or Technical Service Department? https://www.google.com/search?q=true+gdm-35em+wiring+diagram ..
3/1/2023 8:17:39 PM • True... • Answered on Mar 01, 2023
True tbb-3g fridge, left hand door sags, creates an air gap at the bottom of the frame where it meets the cooler, door lifts about 1/4 of an inch on the post
If the left-hand door of your True TBB-3G fridge is sagging and creating an air gap at the bottom of the frame where it meets the cooler, here are some steps you can take to fix the issue:
  1. Check the door hinges: Inspect the hinges on the door and the frame of the fridge. Look for any damage or wear that may be causing the door to sag. If the hinges are damaged, they may need to be replaced.
  2. Adjust the door hinges: If the hinges are in good condition, try adjusting them to see if this resolves the issue. Use a wrench to loosen the screws that hold the hinges in place, and then adjust the hinges up or down as needed to align the door with the frame. Tighten the screws back in place when you are finished.
  3. Check the door gasket: If the door gasket is worn or damaged, it may not be sealing properly and causing air gaps. Check the gasket for any damage or signs of wear, and replace it if necessary.
  4. Check the door closer: The door closer on the left-hand side may be damaged or worn, causing the door to sag. Inspect the closer and look for any signs of damage. If it is damaged, it may need to be replaced.
If none of these steps resolves the issue, you may need to contact a professional repair service to help diagnose and fix the problem.
2/28/2023 5:20:05 AM • True... • Answered on Feb 28, 2023
P1 error code True T-49 refrigerator
2/1/2023 6:28:13 PM • True... • Answered on Feb 01, 2023
2answers
One month old True T-23 not cooling to set temperature. Display is unlocked and set temp is 36 degrees but fridge is continually at 57 degrees
It's possible that the issue may be with the thermostat or the compressor. If the thermostat is not working properly, it may not be regulating the temperature correctly. Similarly, if the compressor is not working properly, it may not be able to cool the fridge down to the desired temperature. It's best to have a professional take a look and diagnose the issue. Another possible cause is the refrigerant levels, if the refrigerant is low this can cause the compressor not being able to cool the fridge properly and will need to be refilled by a professional.
1/29/2023 11:03:02 AM • True... • Answered on Jan 29, 2023
True refrigerator tuc-24g-hc-fgd01 Error 13
This is a $3,600 commercial undercounter fridge. Great make and I have used many of them in my 50 year catering career. There is nothing on fixing Error 13. Pages 76 and 79 state 'Communication Error'.
TEMPERATURE CONTROL ADJUSTMENTS - NET
https://dc2kentprodcontent.blob.core.windows.net > ... PDF TDM (True Display Merchandiser) Refrigerator. Holds 33?F to 41?F (0.5?C to 5?C), ... Temperature. Communication error. E13. -. CURRENT CONTROL DISPLAY.
Contact Technical Support direct for how to fix. https://www.truemfg.com/NA/Products/Bajo-Mostrador/TUC-24G-HC~FGD01 ..
11/22/2022 5:49:04 PM • True... • Answered on Nov 22, 2022
Why does our Commercial True 3 door Freezer keeps tripping breaker?
The freezer door being open all night cause the compressor to run all night continuously trying to cool the unit down. This caused an increase in resistance and tripped the breaker. It may stabilise, but it may need a service call to fix the issue. It may also be a lazy breaker and it is the breaker that needs swapping out. you can normally compare them against adjacent breaker, a lazy one feels soft and doesn't snap of Off when you move is slowly to the Off position. They also feel different when switching to On. I have spent a 50 year career in catering and hospitality fighting fridges and freezers, electrics and plumbing. Now retired :>) Get this fixed by Easter because in my experience, it will break down on Saturday at 8:00pm!
4/7/2022 11:28:31 PM • True... • Answered on Apr 07, 2022
True GDM-33-SSL-54 Refrigerator Logo
21 questions posted
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
True Refrigerators
  • True Refrigerators
Most Popular Question
true gdm 33 refrigerator icing up around
  • Refrigerators
