Eureka Vacuum Cleaners; AIRSPEED One Multicyclonic Upright Logo
A
Anonymous Posted on Apr 13, 2014
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
My Eureka Multicyclonic vaccuum cleaner isn't picking up any dirt and the roller isn't spinning. What can I do to solve the problem?
Level 3:
  • Master 7,733 Answers
  • Posted on Sep 13, 2015
Master
Level 3:
Answers
7733
Questions
0
Helped
1865083
Points
21487
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Nov 30, 2008
SOURCE: eureka, whirlwind 12 amp vacuum does not pick up anything
That problem can be caused by the belt being stretched out and even though it is spinning when you look at it, with the resistance of the carpet it will stop.
With a model number I could tell you exactly how to change the belt, but most of the whirlwinds I've seen are similar.
You need to gain access the belt and roller. On most models there are two screws on the top of the nozzle inside one of the four indentions that run along each side. Once you take those out it allows you to take the hood off.
Remove the brush roller and old belt. Wrap the new belt around the motor shaft and place the roller through the belt loop and use the roller as leverage to stretch the roller back into the roller housing. It will take a little muscle. Give the roller a spin by hand before putting the hood back on. It should spin easily. If it doesn't then you might have pinched the belt and need to free it or the belt will just burn up when you turn the unit on.
A clog in the hose going down to the nozzle would also cause this problem, so check that hose when you take the hood off.
Anonymous
  • 134 Answers
  • Posted on Feb 22, 2009
SOURCE: eureka altima 2993av bagless
Hi
Sounds like its blocked. Check under the glide plate and the hose. Look in the book for model specific details
Anonymous
  • 701 Answers
  • Posted on Nov 19, 2009
SOURCE: eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Anonymous
  • 701 Answers
  • Posted on Nov 20, 2009
SOURCE: i have a eureka altima bagless and it wont pick up
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Anonymous
  • 701 Answers
  • Posted on Jan 02, 2010
SOURCE: I have a Eureka Altima vacuum cleaner that doesn't
That means that you need to replace the belt. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Eureka multicyclonic
Hi, it's Jeremy from Crucial Vacuum.
Attached in the link below is the owners manual for your Eureka AS2030A. Provided is step-by-step instructions on how to assemble your vacuum.
http://www.manualowl.com/m/Eureka/AirSpeed-ONE-Pet-AS2030A/Manual/350835?page=1
You can purchase direct your Eureka replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Eureka multicyclonic will turn on but not stay on
check for plugs, if not plugged could be a switch or a cord short.
Eureka multicyclonic keeps turning off
Start by replacing the filters. If it's clogged the motor will shut off because it gets hot
1helpful
Burning smell and not picking up dirt
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
