Computers & Internet Logo
A
Anonymous Posted on Apr 12, 2014
Computer won't move from 'starting windows' screen
I can hear hard drive and cpu working but nothing happens other than the start up screen showing
Q4SteveB
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on Mar 30, 2016
Q4SteveB
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
113965
Points
250
At power-on, use F12 (or F8) and select 'Repair' ... DO NOT let it 'reformat' your drive or you will loose everything ..
If that fails, you may have to choose 'Factory Restore', but this will re-install Windows and you will LOOSE EVERYTHING !!
SO == if you have another PC, I suggest move your disk drive to that other PC and copy off all your photos/music/videoa etc you don't want to loose before doinbg a Factory Restore ..
5 Related Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
  • Posted on Sep 26, 2008
SOURCE: computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Mykel_N
Mike Neath
  • 315 Answers
  • Posted on Jan 25, 2009
SOURCE: can't reload Windows XP Pro on Dell 4500
Have a look at these for more info:
http://www.pcuser.com.au/pcuser/hs2.nsf/web/3D2F91493F7B80D5CA256EA80038C9A7
http://www.codeproject.com/KB/work/installwindowsxp.aspx
http://lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php
I hope that helps.
Anonymous
  • 381 Answers
  • Posted on May 09, 2009
SOURCE: I ahve an emachine T6524 and when you start it up
hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Jun 15, 2009
SOURCE: Dell Dimension 8300 Windows XP won't boot, just blank screen
Start by taking the motherboard battery out for a minute and cleaning and reseating the ram (memory), then try to reboot.
Post back foe more advice if needed.
Good luck
Anonymous
  • 1865 Answers
  • Posted on Aug 07, 2009
SOURCE: Computer cannot boot - just beeps when switched on
Remove and reseat your RAM chips
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
the 4 caused, 99% (and more sure) an OLD 2003 LAPTOP....
1: the HDD is bad. we test it , ask how. (moved to good PC)
2: the coin cell battery is dead and bios lies about HDD. 11 years old is no good now, ever, 7 years is EOL on COIN.
3: The OS is infected well gee XP is a virus magnet. so is.
4: and more. gee the screen works as most do not now CCFL EOL.
Trying to start Lenovo laptop but just the "Lenovo" word shows up & nothing happens
Try to remove your hard drive. The company I work for uses mainly lenovo laptops and we have found if a hard drive goes faulty it will hang at this LENOVO screen. if you remove it and it progresses to the bios (it won't load windows since the hard drive is not in the laptop) you might need to consider replacing the hard drive and reinstalling windows.
Please contact me at this no.9213261399
If you hear a clicking sound when the hard drive is trying to start up; then the drive is defective. If nothing happens when you start the computer, the operating system and/or drive are faulty. You need to get a replacement drive and install Windows again.
Asus k50ab won't start up or post
Jacob - have you had any success at fixing your laptop? If so, I would love to hear what the issue was. I have a friend that is experiencing the same issue.
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
My Seagate starts to boot up but then goes to a dark blue screen(no words) and you can hear the H.D> working, then the computer beeps once and nothing further happens.
the blue screen, is usually a Hardware Or Software ( operating System error ) The Computer beeping Once, States that The Computers Hardware is Fine. I,d try formatting the hard-drive, and reinstalling Your Operating System et,c. I,d assume this is a missing or corrupt windows system file. Or possible hard-drive error. ( virus-Trojan-Worm ) are also suspect.
Mike @ Compurepair.
Only shows compaq on screen
I work with Compaq computers now and usually your problem points to the hard drive. I know Compaq's will stay on that screen if the hard drive has failed. Try another hard drive would be my suggestion.
Hope this helps.
1helpful
Computer won`t start
tell me!
Open Sky
2answers
Cpu /monitor
Hi, Sounds like video card problem. Try removing, cleaning the gold contacts and re-installing to the slot. If your PC uses an on-board video that shares with the memory, then you have to remove your memory and clean the gold contacts then re-insert back and try again. If cleaning, re-inserting/re-seating does not solve the problem, then perhaps replacement is required. Hope this be of some help/idea. post back how things turned up or should you need further information. good luck and kind regards.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
