20 Most Recent
Dell Precision 380 P4 Dual Core 3 GHz (99382) PC Desktop Questions & Answers
Yellow Amber light on Dell Optiplex 390 not booting or display what to do?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Boot up problem with Dell Precision 380 P4 Dual Core 3 GHz
Your computer is trying to boot from a floppy drive. Do you even have one? If not, then you need to go into the BIOS (set-up) menu and disable it. Be careful though, you could loose all your data on the computer if you make a wrong selection. As for an array message, you must have have a RAID disk configuration. That means you have 2 or more disk drives that mirror each other.
Dell Precision workstation 670 - System is locked
If this is a PC follow these steps.
1.!!! IMPORTANT !!!! Turn the computer off and unplug it.
2. Open the tower and locate the mother board. This will be the largest board that everything is link to.
3. You will see a watch like battery, remove it.
4. Wait 30 seconds to a minute.
5. Now replace the battery and close the tower
6. Power up the computer and your login request should be removed.
This maybe the same for laptops
Bios password set
remove battery, boot to system settings, re-insert battery, CMOS PW should now be cleared
Usb ports not working
if your computer came with a motherboard disk the drivers
could be on it
click start control panel administrative tools computer
management device manager scroll down universal serial bus controllers you
could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails
to fix the problem
check the USB leads that attach to the motherboard usually
red white green black make sure they are securely seated and have no dust build
up on them dust will cause static and a lot of unforeseen problems for a
computer and its parts
Windows 7
First, please disconnect all USB devices and then perform
the following steps:
Click Start button, type devmgmt.msc in the Search bar and press Enter. Click Continue if necessary.
In Device Manager, double click to expand Universal
Serial Bus controllers, right click on the Host Controller, click Uninstall and click OK.
Repeat the step 2 to uninstall all items under Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all
USB controllers automatically.Rather doing a driver hunt
which can take hours
http://ct.download.com/clicks?t=1179231350-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to
update every driver individually once you update you might be asked whether you
want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart
once all of the drivers have been updated.
if you need more help with this post a reply
Flashing amber light on power button
Correct, the only step you can try is to reseat the memory chips. it should fix the problem. the power supply seems to be good here, as well as bad.
confused?
why good? becasue it is supplying the power to the computer and the only reason you see the light on the tower.
why bad? becasue the power supplied is not enough for the computer to start.
Now, the power is going to the motherboard, if you see any light on the motherboard the power supply is okay and then it became the duty of the motherboard to forward the power to all the components. so reseating the cables on the motherboard should fix the problem, most probably memory can cause such problems. so keep your fingures crossed and then restart the computer after you done resseating the memory and other cables, if it still doesnot work. then you may need to use the hit and trial method to find out if its a power supply or motherboard.
we normally replace both the parts in such cases.
all the best.
