Computers & Internet Logo
A
Anonymous Posted on Apr 09, 2014
How to connect tp link router (Model- TL-SF1005D Ver-10.1) with ptcl wifi modem
Could not work
Huseyin Huseyin
Level 3:
  • Master 3,469 Answers
  • Posted on May 30, 2015
Huseyin Huseyin
Master
Level 3:
Answers
3469
Questions
Helped
767137
Points
11197
Try dlink.com or just google the URL
http://support.dlink.com/emulators/wbr2310/lan.htm
3 Related Answers
Anonymous
  • 85 Answers
  • Posted on Apr 23, 2008
SOURCE: TP-LINK 54M Wireless Router
pls ckeck your connectivity status
use this command to test for connectivity from your isp 'ping <ip address>
Anonymous
  • 5 Answers
  • Posted on Jun 07, 2011
SOURCE: i recently purchase a TP
Are you using straight cable or cross cable. you must use straight cable for configuring this router. If LAN light does not turn on after using straight cable then there must be problem with router itself.
Anonymous
  • 3 Answers
  • Posted on Dec 16, 2012
SOURCE: How do I connect TP-Link & D-Link to base P.C.
http://www.tp-link.com/en/products/details/?model=TL-SF1005D#down
2answers
Bsnl adsl modem configure with TL-MR3420 router!
TP-Link Router not working, want to setup TP-Link router, have troubleshooting issues. No need to worry we are here to provide you the best solution according to your requirements of router issue. You just need to dial TP-Link Router Helpline Number avail at toll-free number 1-833-284-3444. Our tech support team includes executives who are professional and know each & every solution which may arise at the time of accessing.
The wireless network is unstable via my wireless router/modem router
Some time router is not still connected and working that time users do follow given instruction and make the trouble-free router.
Locate wireless clients in a reasonable distance.
Get away from obstacles.
Reduce the number of wireless clients.
Decline interference from other wireless equipment.
Optimize the router's position.
Change some settings on the router.
Test the WIFI device.
Get technical service for your problem which is not understanding how to solve the technical issue, our technical expertise is available for 24*7 and they are ready for pick up the call when called by the customer. If wants to more technical service visit our TP-Link Router Service websites.
https://servicenumber.org/tp-link-router-customer-service.html
1helpful
I have lost/foregotten my WiFi password.
no problem used the cd that came with the router run it again and reset your password follow the instruction!!!!
TP-Link TL-WR841N Wireless-N300 Router dropping connection
Do you experience problems with other WiFi hotspots?
How to convert a tata photon in to a wifi connection
First, you need an internet gateway. Do you have already some kind of internet connection through DSL, CABLE Modem, etc? The TP wifi will first have to be connected to your network (wired LAN). Then, once that is done, you need a computer with web browser to access and configure the setting in the TP. There is a CD that comes with the TP. It contains "Easy Setup Assistant" program to configure your TP wifi.
How to connect wifi
Connect ISP modem to main RJ45 connection. Them simply connect PC to any other port. Wireless network connection requires discovery of your network from device(s).
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
2answers
How to configure TP-link TL-wr340g on tata broadband
If you don't have any internet access, you can reset the router by unplugging it from power and then plug it back in. Do the same for your ADSL or cable ISP modem which you have connected on your TP-Link router.
RESET FIRST YOUR ADSL MODEM and then your router.
Other solution might be to do ipconfig /release and ipconfig /renew on your command line window from your computer.
You can find your wifi router's user manual (PDF) on this link:
http://www.tp-link.com/resources/software/200943083466.pdf
Please mark as solution if this helped you at all.
Thanks.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
