Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Mod Logo
N
Norma Richard Posted on Apr 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The putdoor temperature will not come in - Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Mod
h2oskierfl95
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 59 Answers
  • Posted on Apr 08, 2014
h2oskierfl95
Expert
Level 2:
New Friend:
Cheetah:
Answers
59
Questions
0
Helped
11777
Points
256
Check batteries in outdoor unit and try moving to closer to the base station.
Why does my lasko 5842 model keep kicking off and I keep the filter clean
answer is in instructions
Save-Smart®
Press () to activate the Save-Smart®Function.
1.Set the thermostat to desired temperature using the +/-
buttons (Note: The default Save-Smart®temperature is 72 ? F)
2.When you reach the temperature at which you want to
set the unit, the set temperature will flash several times
and then the display will return to indicate the current
room temperature and will gradually change as the
room temperature changes.
3.When the air temperature is less than the set temperature,
the heater will run in HIGH heat.
4.Once the thermostat reaches the set temperature the heater
will automatically switch to LOW heat to save energy.
5.When the air temperature reaches 4? above the set temperature,
the heater will turn off. The Heater will cycle off and on in the LOW
mode to maintain the set temperature.
All this happens automatically with Lasko Save-Smart®Technology.
To deactivate the Save-Smart®function, press Save-Smart®
again or (hi/lo) for continuous high/low heat.
AUTOMATIC TEMPERATURE CONTROL(Figure 3)
The automatic temperature function will only operate on "High" heat.
You cannot set the temperature automatically when the unit is in the low heat mode.
1.To set the room at a specific temperature press the () or()buttons
to the desired temperature. The display will now reflect the () and the temperature will be flashing. The Heater is now in Auto Temperature Mode.
2.When you reach the temperature at which you want to set the unit, the set temperature will flash several times and then the display will return to indicate the current room temperature and will gradually change as the room temperature changes. NOTE: the temperature display does not indicate the temperature of the heated air being emitted by the heater.
3.Once the room temperature reaches 2 degrees above the set temperature, the Heater will shut off. Once the room temperature reaches 1 degree below the set temperature, the Heater will turn back on and continue to cycle off and on to maintain the set temperature.
4.This function will cancel if the ()button is pressed. The Heater will now be in High heat and run continuously.
NOTE:It is normal for the Heater "fan" to run for approximately 15 seconds when the Heater shuts off after reaching the set temperature.Press the () and() buttons at the same time to change the display to ° Celsius. Press the same two buttons together again to change the display
back to ° Fahrenheit.
tip
How can test Laptop?s temperature and temperature should it be at?
<p><span>If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.</span><br /> <p><span><span> </span></span><br /> <p><span>Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.</span><br /> <p><span> </span><br /> <p><span>Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.</span><br /> <p><span> </span><br /> <p><b><span>Speed Fan</span></b><span>- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.</span><br /> <p><span><span> </span></span><br /> <p><b><span>Real Temp-</span></b><span> The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.</span><br /> <p><span> </span><br /> <p><span>These tips may help you to determine the exact temperature for your laptop. </span><br />
on Dec 24, 2010 • Computers & Internet
Where is the temperature control knob on Frigidaire upright freezer model #CFFH17F1RW
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
2006 Silverado, with a/c running and cold on both sides for 2 hours or so then the drivers side gos hot passengers side cold at the same time.
Manual or automatic climate control ?
Have you had the HVAC control panel checked for DTC'S - diagnostic trouble codes ?
Air Temperature Sensors
The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
• Ambient Air Temperature Sensor
• Inside Air Temperature Sensor Assembly
• Upper Left Air Temperature Sensor
• Upper Right Air Temperature Sensor
• Lower Left Air Temperature Sensor
• Lower Right Air Temperature Sensor
A signal and a low-reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40°C (-40°F) to 101°C (215°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
• DTC B0174 Output Air Temperature Sensor (Upper Left) Circuit Range/Performance
• DTC B0179 Output Air Temperature Sensor 2 (Lower Left) Circuit Range/Performance
• B0414 is for the left air temperature actuator.
B0408 is for the left air temperature actuator.
DTC B0989 Output Air Temperature Lower Sensors Correlation
The HVAC control module monitors the upper left and upper right duct temperature sensors when the mode switch is in the VENT or BI-LEVEL positions. The HVAC control module monitors the lower left and lower right duct temperature sensors when the mode switch is in the DEFOG, FLOOR or FRONT DEFROST positions. The duct sensors are used to measure the temperature of the air exiting the ducts to help maintain a consistent cabin air temperature. These duct sensor inputs provide the HVAC control module a way to determine if the engine needs to be started to maintain a specific air temperature. If an upper duct sensor circuit failure is detected the HVAC module will not request an engine start to help cool the cabin. A lower duct sensor circuit failure will not prevent the engine from starting.
DTC B0990 Output Air Temperature Upper Sensors Correlation
Your best bet , take it to a qualified repair shop .
Where is a air temperature control sensor in a 2004 GMC Canyon located at
There is none on your vehicle , temperature control is by a cable .There is a evaporator temperature sensor , this is used to keep the evaporator from freezing up !
Air Temperature Control The air temperature control regulates the HVAC system air temperature in any mode. An air temperature control cable mechanically links the air temperature control to the air temperature door.
Evaporator Temperature Sensor The evaporator temperature sensor will not allow an A/C request to the body control module (BCM) at temperatures less than 0°C (32°F).
My 1998 gmc jimmy slt has a heating problem. The heater wont turn off. As long as the car is on the heater is on full blast. The fans work and everything knob wise works but the heater is always on.
The air temperature valve electronic actuator positions the temperature door according to the temperature setting of the temperature control on the temperature control knob. For the full COLD temperature setting, the temperature control returns approximately 12 volts to the air temperature valve electric actuator. When the temperature setting is changed to full HOT, the temperature door is moved to the warm position and the output drops to about 0 volts. For a temperature setting in the mid range, the temperature door is positioned according to the voltage supplied through the temperature control switch.
Temperature Control Inoperative
Inspect the HVAC I fuse 21.
Is the fuse open?
Go to Step 20
Go to Step 3
  1. Disconnect the air temperature valve sensor.
  2. Turn the ignition switch to the RUN position.
  3. Move the headlamp switch to the PARK position.
  4. Using the J 35616-A , connect a J 39200 Digital Multimeter (DMM) between cavity 8 (CKT 733) of the air temperature valve motor connector and ground.
  5. Move the temperature control knob from the HOT position to the COLD position.
Does the voltage vary smoothly and continuously within the specified range?
0-12 V
Go to Step 4
Go to Step 9
Using the J 35616-A , connect a J 39200 DMM between cavity 10 (CKT 341) of the air temperature valve motor connector and ground.
Does the voltage equal the specified value?
B+
Go to Step 5
Go to Step 7
5
Using the J 35616-A , connect a J 39200 DMM between cavity 10 (CKT 341) and cavity 7 (CKT 1850) of the air temperature valve motor connector.
B+
Go to Step 6
Go to Step 8
6
Replace the air temperature valve motor.
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
04 Tahoe AC blows hot air on drivers side but resets if restarted
A educated guess I would have to say there is a problem with HVAC control module ! electronics you know ! But that's not the way to do things ! There could be codes stored in the module. The Chevy dealer my have a reflash bulletin for this problem . Then can reflash , reprogram the control module ! The first place to start is checking for codes in the HVAC module.
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal.
Air Temperature Sensors The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
Inside Air Temperature Sensor Assembly-Auxiliary
Upper Air Temperature Sensor-Auxiliary
Lower Air Temperature Sensor-Auxiliary
A signal and low reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40?° to +101?°C (-40?° to +215?°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside air temperature sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
If the HVAC control module or auxiliary HVAC control module detects a malfunctioning sensor, then the control module software will use a defaulted air temperature value. The default value for the ambient and inside air temperature sensors will be displayed on the scan tool. The default value for the duct air temperature sensors will not be displayed on the scan tool. The scan tool parameter for the duct air temperature sensors are the actual state of the signal circuit. The default action ensures that the HVAC system can adjust the inside air temperature near the desired temperature until the condition is corrected.
The ambient air temperature sensor mounts underhood and can be affected by city traffic, by idling, and by restarting a hot engine. Therefore, the HVAC control module filters the value of the ambient air temperature sensor for temperature display. The ambient air temperature value is updated under the following conditions: Or you can just buy a new control module an hope that it fixes it. $89.00 at www.partsgeek.com
Search from over 10 Million Auto Parts
2answers
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Top Oregon Scientific Measuring Tools & Sensors Experts
Dave Parker
Dave Parker
Level 1 Expert
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
