Supply power to the phone and scroll through the menu or just get a manual on line for that model number and read how to move from one language to another.
1. Select the round Menu/OK button Then > Settings > Language > English . Should be done.
Since it's in Spanish currently, you may have to go to Settings > Language > Others > English. Let me know what happens. If you need further help don't hesitate to ask. Thanks for using FixYa.
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
Go to the flash program button and press that button until you see Setup Language- 1 English 2Spanish 3French use the caller id buttons to scroll to the 1 English and that will set your language for your phone.
Oh boy that's a real problem. I guess the menu is there but you don't understand it because it's in Spanish.
I don't know this particular phone but thinking logically, there are four things I would consider.
1) Find someone who can speak Spanish, there are lot of people who can.
2) Find someone who has the same phone that is in English and copy the key presses.
3) Use Google language tools to help you interpret the Spanish menu
4) Take you phone to a dealer
