Misfire cilynder 3
SOURCE: misfire on cylinder 4 & 5. combustion miss with cylinder cutout.
the best way to diagnose a misfire is to move the ignition coils of those cylinders(4 and 5) to different cylinders to see if the misfire will move. you can also move the injectors around and even the spark plugs.(make sure to keep a good record of where you are moving them). if you can't get the misfires to change cylinders. your next step would be to do a compression check on all cylinders. air leaks in the intake system can cause misfires but usually it isn't on the same cylinders all the time
SOURCE: BMW 523i 1999 model
your car is not suppose to idle at 500 rpm . 800 to 950 is the proper idle, unfortunately it is controlled by the computer. have you checked the idle speed control valve? also check the air flow meter
SOURCE: 2001 bmw 325i is misfiring?
misfire happens because there is still fuel not burned in the cylinder so when its pushed out its burned in exhaust tube because the heat thats why you hear these small explosions. this caused if your sparking pluge not firing well . or there is a leak in the intake valve . in your case i advice you to check your sparking plug . if this helped pls vooote
SOURCE: I have a BMW 3
P0300 indicated a multiple cylinder misfire. Typical causes are vacuum leaks, bad plugs, wires and/or coils. Could also be a dirty MAF. From what you describe it could also be the seal between the air cleaner housing and the MAF. Make sure the o-ring is not out of place and dry. I put some silicone lube or vasaline on it to help seal things up. That fact that it acts this way when cold points in the direction. That's what I would check first. Let me know how it works out.
It can be issue with spark plugs or faulty spark plugs. Also
get the compression test done for cylinders. If any of cylinder shows low
compression then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know
which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help
oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla:
Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
