Keeps saying ice full but no ice
I searched forever for an answer to this and never found one. So this is what I did when you take the cover off on the left hand side there are two switches with two wires coming from.each switch. Then in the same group of wires the is two slightly larger wires one red one black. Those wires go to the optic eye that tells the machine is full. Cut and splice these teo wires together coming from the circuit board this will tell the machine it is empty and should make ice. Worked for me. It just doesn't cut off on its own whenever its full.
Took the plunge and did the above splice of the black and red wires . Works great, must manually shut it off, or just don't fill as full of water so it doesn't overflow. Note, you only need to remove the screws from the back bottom of unit. Wires are on the left side of unit with it facing you.Thanks.
Worked great! Thanks
Worked fantastic, thanks
Yep, that did the trick. You need a bag full of tricks to keep these little devils running. Many thanks for this one !!
My husband took mine apart last night to find out that the sensor inside that tell you that the ice is full had gotten water in it and the wires coming out of the little LED bulb rusted & broke off, now trying to find a replacement has become very challenging!
Worked like a charm!!! Thank you so much!!
Took the plunge and did the above splice of the black and red wires . Works great, must manually shut it off, or just don't fill as full of water so ice doesn't overflow. Just add more water as ice is needed Note, you only need to remove the screws from the back bottom of unit. Wires are on the left side of unit with it facing you.cut and splice them together, bypassing the electric
eye which signals "full."Thanks.
Sounds like a thermistor located in the bin
