20 Most Recent Jenn-Air Freezer Jenn Air Clear Cube Ice Maker Questions & Answers
Ice maker model # HDIM35 will not make ice
1/2/2018 2:43:00 PM • Jenn-Air Freezer... • Answered on Jan 02, 2018
We have had our jenn
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help Keep this link for future resource I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 11:52:46 AM • Jenn-Air Freezer... • Answered on Dec 31, 2017
WHERE IS THE WATER FILTER LOCATED ON MODEL # JSD2789DES
Hi Check behind the cover at the back of your fridge.
2/23/2014 12:11:12 PM • Jenn-Air Freezer... • Answered on Feb 23, 2014
Ice maker leaking out the bottom and refreezing
are the cubes coming out of the unit? Sounds like the heating element is not activating, to release the cubes prior to refilling. Check electrical connections at the rear of the unit against the freezer wall that they are together. If ok then defrosting element may be defective, Replace unit.
8/29/2013 1:14:59 PM • Jenn-Air Freezer... • Answered on Aug 29, 2013
Need installation instructions and owner manual
Call the company,they will either mail you one or give you a website to download one.
1/30/2013 6:07:47 PM • Jenn-Air Freezer... • Answered on Jan 30, 2013
2answers
I have a Jenn-Air Refig with the freezer on the
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
10/3/2011 6:05:52 AM • Jenn-Air Freezer... • Answered on Oct 03, 2011
The ice maker won't stop
Hi slh3095,
The easiest way to stop the ice maker in making ice is by raising the shut off arm.
Please check if the shut off arm can move freely.
Here are additional steps that you can apply to stop the ice production:
1. Raise the ice maker's shutoff arm until you hear a click and the arm stays in the up position. The ice maker will remain off until the shutoff arm is pushed down.
2. The shutoff arm is designed to automatically stop ice production when the ice bin is full. Using an ice bin other than the one designed for use with the refrigerator may not allow the shutoff arm to stop ice production.
3. Ensure that food packages, ice packs, etc. are not obstructing the wire shut off arm so it can move freely.
Hope it helps.
Thank you for using FixYa.
6/1/2011 1:31:38 AM • Jenn-Air Freezer... • Answered on Jun 01, 2011
My jenn air ice maker is not filling up the water
Change filter and clean out lines.....
download the service manual here-->http://www.wazhua.com/maytag-ice-maker-troubleshooting-tutorial.html
Thanks for rating Good luck
2/10/2011 8:45:22 AM • Jenn-Air Freezer... • Answered on Feb 10, 2011
We have a Jenn-Air Refrigerator/Freezer
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too.
Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
1/27/2011 3:43:31 PM • Jenn-Air Freezer... • Answered on Jan 27, 2011
One cube has a face equivalent to the total area
Let the sides of the cubes be a and b,
the length of the diagonal of the cube whose side is b is given as square root(3)*b
according to the given question,
a=square root(3)*b
the volume of the cube with side a is given as
v1=a^3=(square root(3)*b)^3
and the volume of the cube with side b is
v2=b^3
then their ratio of volumes is given as
v1/v2=3*square root(3)*b^3/b^3=3*square root(3)
i.e v1:v2=3*square root(3):1
Next qwasthun pwease :D If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/6/2011 3:30:50 AM • Jenn-Air Freezer... • Answered on Jan 06, 2011
Keeps making ice and fills up bin. I checked the
Usually the system continues It's operation when the thermostat is defective,Replace thermostat and check the operation of the system.
11/30/2010 8:59:10 AM • Jenn-Air Freezer... • Answered on Nov 30, 2010
Jenn aire refrigerator not completely
Increase the inside coldness by rotating the termostat switch nob to a higher number position.
10/4/2010 4:32:30 PM • Jenn-Air Freezer... • Answered on Oct 04, 2010
Ice maker will only make crushed ice and no cubes,
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
9/19/2010 2:03:32 PM • Jenn-Air Freezer... • Answered on Sep 19, 2010
Freezers Logo
76 questions posted
Top Jenn-Air Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jenn-Air Freezer Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Freezers
  • Jenn-Air Freezers
Most Popular Question
need installation instructions owner
  • Freezers
