Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
Posted on Jun 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOBART AM15 DISH WASHER ERROR(E1) - Hobart 29 in. AM15-1 Free-Standing Dishwasher
Anonymous
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on Jan 12, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
110
Questions
0
Helped
71523
Points
195
Are you sure you dont have a bad display, there are no e1 err. for the am15,e2,fill prob.e6sensor,ed,slow leak,ee, bstr not to temp.ef, iternal control err. if it displayed p1 that is an open or shorted wash thermister
paultech8226
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Aug 14, 2009
paultech8226
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
63584
Points
156
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
Hobart AM15-1 dishwasher. Good morning, why does 'DP' appear on the display and immediately after that it starts washing and does not show the temperature on the display?
Question edited for a lot more clarity. All question need FULL 'make model (what it is)'.
Question moved from laundry Washing Machines to Hobart Dishwasher category.
'DP' or 'PD'?
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Manual just for fun.
https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf
I have a Hobart LX18C. New control board now turns on, but it says "18H" when it starts up and shows a P3 error code. I think it's confused because it's a C model (low temp) not H (high temp).
Error P3, Rinse Tank Booster Thermister is faulty
SOLVED: Hobart LXI Dishwasher a P3 code is flashing ...
https://www.fixya.com > support > t4318217-hobart_lx...
Mar. 11, 2010 - It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you ... 1 answer · 11 votes: The p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ...
SOLVED: What is p3 code on hobart am15 dishwasher - Fixya
Sep. 2, 2019
SOLVED: What does a P3 code mean? On a Hobart LXI high ...
Jan. 5, 2014
My hobart am15 display a p3 error code and i make - Fixya
May 1, 2010
SOLVED: Error code "p3" appears in the digital panel with a ...
May 12, 2010
More results from www.fixya.com
18H doesn't exist
https://www.google.com/search?q=hobart+lx18c+18H+error+code
Hobart am15 scrolls message drain and de-lime with a constant beeping??
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
18helpful
2answers
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
All the wires been trip by some one so i need to wire it up
Can you confirm if you have an AM14 or AM15. Check the data plate and give the Voltage spec., ML number, if you have it.' Please confirm what you mean by the wires are trip.
15helpful
6answers
Error code E2 (with a picture of a wrench)
E2 means a problem with the fill. The wrench means to contact Hobart for service
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
