Just bought a Gold's Gym 420 treadmill and it was working fine a couple days ago. I went to get on it this morning and it plugged in a but the start stop, preset workouts and speed and incline buttons do not work along with some of the preset speed buttons. Only 1,5,8,10 work for speed and 1,6 for incline. I thought it might be in demo mode but after reading how to undo that, nothing works. It goes from like 1-15 in preset workouts flashing each one. Seems like it is **** in Demo mode. Just curious as to why now and any help on how I can fix it would be greatly appreciated.
Here is a link to the manual pay close attention to page 16 this will tell you how to see if it is in fact in the demo mode and how to cancel it. Some thing to remember about the display is that it is a matrix with contacts going both horizontal and vertical if one is broken some buttons will work and other won't. You may want to remove the console and clean the ribbon cables.
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
SOURCE: Treadmill squeaks
There's a special silicone-based treadmill lubricant that you put between the belt and rollers See this treadmill accessory kit
SOURCE: My proform 515s Crosswalk treadmill works for a
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt. 4. After completing the steps above go to your local hardware store and purchase a can of silicone spray ( Pyroil, Napa etc ) attach the nozzle and proceed to spray length wise starting at the motor shroud to 2/3 down the deck repeat the process on the other side then re-tension the belt according to you owner's manual. Start unit and proceed to walk on it if the unit shuts down again then belt and deck needs to be replaced or your in the market for a new treadmill.
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
SOURCE: Treadmill won't start. Console works but when
If the console takes
batteries, replace them. If this does not work or your console does not require
batteries, check the reed switch or optic sensor. Reed Switch:
Unplug the treadmill and remove the motor hood cover. The reed switch is mounted
on the frame next to the front roller pulley. There is a magnet glued into the
front roller pulley. When adjusting the reed switch, make sure it is pointing
directly at the magnet. Move the tip of the reed switch within 1/8" of the
magnet. Also, check to see that the wire is not damaged, and is connected to
the console
Optic Sensor: Unplug the treadmill and remove the motor hood
cover. The optic disk and sensor are located either at the end of the motor or
the right hand side of the front roller. The optic disk spins between two
sensors on the optic switch. The disk must spin freely without touching either
sensor. The sensors can be moved by loosening the adjustment bolt holding the
switch to its bracket. The switch can then be slid. Center the disk.
Remember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
