SOURCE: Hello I bought transcend external
I can not format a transcend external hard disk.Please Solution it problem.
SOURCE: files disappear
if you are referring to a usb drive click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP hope this helps
you might have restore it to its defaults
Right click on your drive select properties then on customize restore Default in W 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
