if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with post a reply hope it helps
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
58 questions posted
187 Questions
94 Questions
67 Questions
36 Questions
