Spirit Fitness Spirit XT685 Treadmill Logo
Mark LaNasa Posted on Mar 16, 2014
Console locked out
The counsole on my Spirit XT685 reads "Console Locked Out". How do I reset it?
A
Anonymous
Here is the manual. It is very detailed. Spirit XT685 Owner Manual Also here is the contact: Technical service department Mon thru Fri. They are available beginning at 8am Central. The number is 800.258.8511. (USA). I would try a full reset on it first.
  • Gigi
    Gigi Mar 27, 2014
    I had the same problem and just called manufacturer. Hold Start and Enter at the same time. Also, if you go into engineering mode, you can turn off the Child Safety feature (which allows the console to be locked).
Image 19.0Q Treadmill. Console lights up but how to unlock the buttons?
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
My Xbox is locked can u help please?
In order to disable the parental lock on your Xbox console you need to follow the instructions on this Xbox support site.
How to reset forgotten pass code for parental controls on Xbox 360
Basically, in order to prevent smart kids from finding a default reset code and disabling the parental controls without their parent's knowing, each Xbox console has an unique reset code that is calculated from the console's serial number.
So if you are unable to remember your secret question to reset the console yourself, you will have to contact the official Xbox support here:
https://support.xbox.com/contact-us
When you are talking with a support agent, you need to confirm, that you are an adult, and then give them the console serial number.
They will then walk you through the process of unlocking your console.
Incline in lowest position, will not move. Shows ERR on display panel
If you wish to get some details; check the site linked here. Pull up older posts...........
The counsole on my Spirit ct850 reads "Console Locked Out". How do I reset it
If you wish to get some details; check the site linked here. Pull up older posts. Check for treadmill articles.......
My counsole cannot read the game. It says open tray.
If you have the disc reading problem then you will need to stop the heat getting to the sensors on the back of the Xbox 360.
You can do this yourself using a good guide or oyu can send it in.
Its locked up on the page that reads press "A" to continue, it will not read....from my remote(s)
Might be a problem with the System or the wii, if you just bought it take it back to the store and tell them the problem to get a new console.
If that did not help contact Nintendo.
No power to the console of my Spirit Z500 but power button lights
Did you insert the safety switch key to activate the console.
2answers
Ps 2 will not read an games including brand new need for speed undercover
you might need a new disc reader for your PS2 console or clean the inside .DO NOT try to clean by yourself.Look up a cleaning manual
5answers
Sony play station 3
ps2 discs are region locked ps3 games are not so are some dvds the are region locked if you seriously want to play the ps2 games buy them from japan
Top Spirit Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Spirit Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
