If the antenna is screwed to base and you don´t have a phobe in the car, just screw in any one you like, not very short because of radio sensitivity!
BR
Repainting without adequate drying time will cause this. Make sure paint is dry. Use 180 grit sandpaper in swirling pattern to sand down the problem areas, idea is to feather edge the paint so you don't feel and ridges between the transition layers when you sweep your hand over them. Then prime the bare metal, then repaint entire door for best results.
if its a front wheel drive it sounds like your c.v. joints are bad. probably have a cracked boot cover and dirt got in there and grease dried out and joint is bad.
hi yes that would help but rember they are for you to drain with please check the seal rubbers around the boot also there are drain holes in the gully where the rubbers seal make sure they are not blocked check the rubbers are not perished or cracked
Did you check & make sure drain holes were cleaned out in base of unit on roof? When you say overflow, do you mean drip pans under cover on roof unit, and if so, did you inspect them for cracks ? There were some years that experience cracks in drip pans.
I WOTLD PULL THE SPARK PLUGS AND RECHECK THEM.I HAVE INSTALLED PLUGS AND CRACKED THEM OR BENT THE SPARK PLUG END CLOSED.LOOK FOR BLACK CARBON TRACS ON THE PORCELIN OF THE PLUG OR TORN BOOTS
You may have to go to your nearest electronics store or Sirius vendor to see if they have an extension cord...as a Sirius customer i never seen one though......Your best bet is to remount the antenna to the forward part of the roof, towards the windshield.
