Ideally, you'll get a high-powered bulk tape eraser that is designed for video tapes and will work perfectly for audio tapes, as well. An audio tape eraser will work to a point, but usually won't blank them out completely since it doesn't put out a strong enough electromagnetic field to erase videotapes completely. I personally own an old Radio Shack high powered eraser and it works to erase both video and audio, as well as a demagnetizer for old color tv screens (when used at a distance...a bit too strong up close), and demagnetizing screwdrivers (the ones I don't want magnetized, that is). Hope that helps.
to erase tapes all you need to do is record over the stuff already recorded on the tape. There isn't any easy method to simply erase a cassette tape, unless you have access to a strong electro magnet
1. Plug into a standard 110-120V AC power outlet. 2. Select a tape [or similar small object]... 3. Hold the eraser in your hand and squeeze the trigger. The red light indicates that the unit is operating. 4. While squeezing the trigger, place the bottom of the eraser in contact with the item to be erased. Move the eraser slowly in a circular motion over the entire product area but do not release the trigger yet. Make circular passes arount the tape for approximately 10-20 seconds, then slowly withdraw the eraser until it is about three feet away from the tape. Now release the trigger. 5. Turn the cassette or diskette over and repeat steps 3 and 4.
Well the cheapest way is to go into record mode, cap the lens with the black lens cap and record a 'black' picture on the tape. This will erase all the pictures on the tape and leave you with a 'black' screen on the whole tape.
You are able to erase tapes on this machine by holding down the play and rewind buttons together. To clear the entire cassette, you'll need to physically turn the tape over and repeat.
Yeah, a strong magnatic field can erase whole tape at once. You can try it by using Deggausing Coil at TV repair shops, though i have not tried it yet.
