We have a Lanier LD533C printer and it keeps giving us an error message SC555 and it wont print anything. And apparently no one services these printers anymore can someone here maybe help us out?
SOURCE: Lanier Printer LP131n
Don't be mad, but it never hurts to ask if you've checked the following...
Less obvious...
If the answer is that you have done all of this and the issue has not been resolved, I would try looking for obstruction above the primary feeder tray, in the gear assemblies in and around the bottom of the printer and the tray, or around the paper sensor. (a small plastic lever in the front of the tray.
SOURCE: lanier 7320 error message c-41 can someone tell me whats wrong
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
SOURCE: I have a Lanier 116cn
The
machine have problem with the transfer roller or the motor which drives
the transfer is overloaded,
see do the right door is closed good
if
this not helped it will need to be checked by a technician.
