Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
m
mark bryan Posted on Mar 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing hose on a Kohler model numbe K- 10433
The hose part number 1114379 on my Kohler kitchen faucet model number K-10433 sprung a few leaks and I need to see how to replace that hose. There is a plastic "quick connect/disconnect" connection and I do not know how to remove the hose. People at Kohler tried to explain it to me but I could not understand. I am a Disabled Veteran and have difficulties. Thanks Mark Bryan
John
Level 3:
  • Master 794 Answers
  • Posted on Mar 11, 2014
 John
Master
Level 3:
Answers
794
Questions
Helped
290905
Points
3169
Http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
1helpful
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
Can i remove flow restrictor from kohler forte 10433?
There is no small disk behind the aerator in the pullout handle of the K-10433. Where is it? Please help!
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
1helpful
I have a Koiler A112.181M or 157-076-ST kitchen faucet. On the back there is a small hole and it is leaking.. What can I do to stop the leak( A small drip) Thank You Jeff
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
2helpful
2answers
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
