Health & Beauty Logo
A
Anonymous Posted on Mar 10, 2014
Eletric scooter not taking a charge - Pride Mobility Health & Beauty
2answers
Is it best to keep my scooter on charge all the time or what
Keep your scooter on charge doesn't sound right. Usually, eScooters take 3-4 hours for charging and many chargers have a red while charging. These chargers turn the green light on when they completed the charging. Here, you can also read more tips about the take care of your e-scooter or e-bike https://www.insurance4ebikes.co.uk/looking-after-your-e-bike/. However, according to auto experts battery should be full all the time.
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
1helpful
Scooter won't take a charge
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
Jonway eletric start and lights problem.
Recommend contacting your nearest authorized service center directly or online here:
http://www.jonway-motor.com/contact.html
1helpful
2answers
Can i turn e200s electric scooter on at switch when charging
No do not turn on the scooter while charging. When the scooter is on it is consuming power. So if you were to have the scooter on while charging, not only would it take longer for it to charge but it would cause problem for the battery. Because you want it to discharge while charging.
1helpful
2answers
Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
2helpful
I want to get my scooter fixed
Throttle wire is broken and needs to be changed.
Simple job for any good mechanic.
Search in yellow/white pages or nearby) for a reasonable mechanic who can do the job in your budget.
Top Pride Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
