I'M TRYING TO UNINSTALL PROGRAMS I DON'T WANT OR NEED. IT USE TO SAY ADD/REMOVE & NOW IT DOESN'T. THERE'S A LOT I DON'T REMEMBER INSTALLING.
You might want to install a program called CCleaner. Very good with removing programs. If that doesn't appear, there might be a way of removing it from the registry. Use this microsoft article How to manually remove programs from the Add or Remove Programs tool
SOURCE: can't install micro. office on vista
there is an option called programs and features ...
and if u want to install a program install it in a normal way
SOURCE: how to add memory to dell dimension 8200
http://www.tigerdirect.com/applications/category/memory_config.asp?ClsId=100
Enter the following information in the blank
and you should come up with which ram is compatible with your computer
then refer to this link on how to install the ram into your computer
http://static.tigerdirect.com/html/guide_installing_desktop_memory.html
SOURCE: Dell Optiplex GX260 will not shut down.
Could possibly be virus/malware issue. Try running a full scan to see if anything is found.
SOURCE: my mcafee firewall will not fully uninstall
Perform the operations while in safe mode, including the install of the new application and the first virus and malware scans. Safe mode gives you control that you dont have in normal.
SOURCE: tried add remove programs no messenger is there when i try to download nothing happens
Once a program is uninstalled, it's removed from 'Add/Remove Programs'. To get Yahoo! Messenger back, download it from Yahoo! (Link) and install it.
