Computers & Internet Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cd rom won't detect blank cds
My cd rom doesn't detect any blank cds when i insert them so im having trouble in burning music down.
Anonymous
Level 3:
Genius:
  • Master 1,019 Answers
  • Posted on Jun 13, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1019
Questions
Helped
388765
Points
2735
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
I have just purchased an HP Desktop computer and when I burn a Cd for music, everyting seems to work ok but when I try to play that CD on another player in my home, it won't play. Is there a setting...
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
2helpful
Refurbished Dell Optiplex GX280 with DVD/CD-RW Drive will not recognize blank CDs in order to burn music. I was told by the seller that I had to purchase burn software. (I also had to purchase CinePlayer...
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
1helpful
My Compaq Presario desktop will not burn CDs
Perform a system restore and take the computer back to a time before the problems started with burning, or you can download a different media player and try burning with that, real player as a good bit of software to use for burning and Nero is too (Nero is a devoted burning suite)
Get real player here >>>>>>
http://uk.real.com/realplayer/
Get Nero 9 here >>>>>>
http://9-burning-rom.com/index.asp?aff=101&camp=gg_nero_uk&se=google
Good luck
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
1helpful
2answers
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Windows media player 11 will not burn the burn list
Thats an ongoing issue with the WMP11.
I suggest getting software like NERO.
You can also get rid of WMP11 and get an older version.
let me know ASAP.
Mastersage.............................................
Blank dvd media is not reconized
You have to pre-select type of media in your burning program (CD or DVD) before adding files and commencing burning procedure.
2helpful
3answers
AMSUNG DVD WRITER PROGRAMME DISK ( NERO, BG68-01317A REV.00 )
IF you are burn youor CD make sure is read and writeable drive if not
get a dvd burner or cd burner a dvd is for dvd CD rewriteable
a cd is just regular CD blank CD for both make sure format when your computer
has detect 14x or 16x 700GB storage...
HP DVD/CD Burner 300n
Ok try this DO NOT insert the media until you have completed ya assembly... then tell it to "Burn" it will then ask for the media.. at this point insert ya CD... it should be "Detected" and ya Burn should proceed.I have had this work for me before. Also try Alcohol 120% thats a great Burner. As well as CopytoDVD...
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
