20 Most Recent Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Questions & Answers
2answers
Computer will not play dvd or cd, but it does show
The computer has to be told to play the play the CD or DVD automatically if that is what you want. Go to the Control Panel, and find Hardware and Sound, look around for the DVD and CD settings, and change them to play automatically.
11/13/2019 11:53:52 AM • Samsung... • Answered on Nov 13, 2019
My dvd multi player rw
Robert Ashworth wants answers to this question google how to BURN DVD-R? DISC. that m522 is and old RELIC PRE 2001 YEAR, DRIVE, WITH NO SATA PORT, IDE (PATA) ONLY And will never work in any PC lacking PATA ports, 2001 and newer PCs. no way. endless web sites cover this, (how to burn) NO PC stated, nor OS but here is generic answer. .(PC's AC power cable unplugged) 1: insert DVD m522 drive in to chassis., connect power cable and PATA Ribbon cable next 2: power on PC and see modern windows fail to see this device. it is not supported this old. unless XP or Vista OS is used. XP and VISTA have zero support now,. and XP is virus magnet. 3: then insert the DVD-R into the tray and close the tray. label side UP. 4: then run Imgburn.exe (free program. 5: burn anything you want but will not burn stolen, or RIPPed movies. you can say backup 1000s of office files in a directory folder full o f files to the DVD-R disk, it does a great job backing up files.
6/15/2019 11:45:28 AM • Samsung... • Answered on Jun 15, 2019
How to disassemble a Samsung M520
Disassembling a samsung M520 is very risky because it may tamper the warranty and you may not be able to assemble it again. I suggest you call a technician for technical supports
2/2/2017 12:13:45 PM • Samsung... • Answered on Feb 02, 2017
I have an internal super writemaster high scribe speed plus that will not burn a cd. When I try to burn a playlist of music a message states connect a burner & restart the player. I'm using win
Please describe the steps you used to burn a disk including the burning software'version? Is the drive listed in My Computer?
7/6/2014 6:20:25 AM • Samsung... • Answered on Jul 06, 2014
Even when i play a cd or dvd i have played before i still cant get any sound
Do you have the Volume Control icon next to the clock (lower right corner of the screen)?
7/3/2014 4:02:59 PM • Samsung... • Answered on Jul 03, 2014
4answers
Samsung 22x Super Writemaster SH-S223F not reading any disc
im having the same problem with this drive and samsung has not helped at all. i cant even upgrade the firmware because the automatic upgrade program that upgrades the firmware comes up with a warning window right off the start, but the window is the wrong size for the text and you cant quite see the OK button or click on it to continue. just a reflection of samsung quality. nothing but garbage. to me samsung is just a big scam. once they have your money, thats it , 0 support. oh well you got me again samsung, my fault. ill just throw this drive on the pile of samsung.
12/4/2012 10:16:00 AM • Samsung... • Answered on Dec 04, 2012
0answers
My DVD can read a DVD but it cannot read a CD
Hi, First clear the lens of the drive. You can replace the lens of the drive. It will solve your problem
10/18/2011 11:38:19 AM • Samsung... • Answered on Oct 18, 2011
3answers
AMSUNG DVD WRITER PROGRAMME DISK ( NERO, BG68-01317A REV.00 )
IF you are burn youor CD make sure is read and writeable drive if notget a dvd burner or cd burner a dvd is for dvd CD rewriteable a cd is just regular CD blank CD for both make sure format when your computerhas detect 14x or 16x 700GB storage...
9/24/2011 6:40:37 AM • Samsung... • Answered on Sep 24, 2011
0answers
2answers
I want to adjust the
http://www.brothersoft.com/downloads/computer-manuals.html you will have to type in the motherboard in the top search tab
or
http://help-site.com/c.m/
this site will tell you how to use something
hope this helps
7/13/2011 9:41:19 PM • Samsung... • Answered on Jul 13, 2011
Nero nya
not exactly sure nero nya???? need to be more specific on your problem
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ? you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
7/10/2011 8:35:54 PM • Samsung... • Answered on Jul 10, 2011
My samsung combo drive (BG68-00883A
how old is you combo drive?all dvd drives have limitation on using it.in specially in burning..if you reach the number of burning the bulb or the lead will be dead..you need to buy a new one..
7/8/2011 3:47:47 AM • Samsung... • Answered on Jul 08, 2011
My samsung CDW?DVD not working
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd/dvd is getting enough power test all leads that are attached to the cd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
5/14/2011 6:31:10 PM • Samsung... • Answered on May 14, 2011
Help i have a samsung dvd rom SH-M522C i cant read
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
5/8/2011 3:48:54 PM • Samsung... • Answered on May 08, 2011
Can't Play Blu Ray DVD
You must be excited in playing that high definition Blu-Ray disc you have. Regarding your concern, CD-RW/DVD-ROM Combo Drive unfortunately, cannot play this format. You need to have a Blu-Ray drive to play that thing.
Thank you for visiting FixYa! have nice day.
4/23/2011 12:36:42 PM • Samsung... • Answered on Apr 23, 2011
My DVD/CDW combo SH-M522C can
try to run the Microsoft Fix it option to delete the upper and lower filters and if this does not work, update the firmware and try to use a lens cleaner. if nothing works including system restore, it might be time to get a new drive. hope this helps
4/16/2011 6:15:46 AM • Samsung... • Answered on Apr 16, 2011
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
95 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
samsung 22x super writemaster sh s223f
  • Computers & Internet
