The temp on the oven kept going off then the f2 code showed and could not turn off or cancel the oven on the pad. Had to turn the breaker off. Took the back off but didn't see anything obvious. Checked the temp probe and it measured about 1100 ohms.The temp on the oven kept going off then the f2 code showed and could not turn off or cancel the oven on the pad. Had to turn the breaker off. Took the back off but didn't see anything obvious. Checked the temp probe and it measured about 1100 ohms.
Correction the temp was going up, not off. My wife said it was smelling hotter than normal when she first noticed the code.Correction the temp was going up, not off. My wife said it was smelling hotter than normal when she first noticed the code.
You can't post conmments that contain an email address.
Good Afternoon J, this is Z. I'm happy to assist you!
If you are getting an error code F2, it usually means that your range is experiencing a communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) system. I would recommend, however, running a quick test to ensure that this is not a false error code. You do this by resetting your oven by flipping the breaker or unplugging it for approximately ten minutes. If resetting your range does not correct the issue, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
The "F2" error code for this oven means "one or more keys on the keypad are shorted". The correction is to replace the control panel because keypad does not come separate. The part is not available but if you call the number of that supplier I'm sure they may find the part for you. Here is the info.
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Here is what my online service manual for the F2-EO error code says
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board). 2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock)
F2 - E6
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
