SOURCE: car heater blowing cold air and leakage behind the dashboard
IT'S THE HEATER CORE, IT IS LOCATED UNDER THE RAIN GUARD THINGY UNDER THE WIPER MOTOR
SOURCE: blower on heater not working
i am no expert on this type of car but you can try this. first i would see if you got power from the switch. if you can get to them. if no power than i would say it is the switch. but also i would find out if there is a resister for the heater. if there is this could also be the problem. heater resisters chg. the speeds for the heater motor and also make heater motor run. its either located on the heater box or the air evaporator box if it has one.
SOURCE: air conditioner blows hot cold and sometimes not at all why?
hello,seem you need to send your car to authorized dealer to scan the problem,maybe the solution is only synchronizing all the flap,ty
SOURCE: merc c class heater problems centre blowing cold and sides hot
Bad vacuum pod, try using a mini vacuum and the on the valve block behind the glove box take suction on each one till you find the bad one.
SOURCE: air conditioner isn't blowing cold air
Could be a number of things...electrical connections causing the compressor not to run. Turn on AC and turn your thermostat all the way to cool...now visually check to see if compressor is engaged and not just free wheeling. Most likely you lost your refridgerant due to leak in the system...would need to find leak and repair then have your system re-charged with refridgerant. Best case scenario...your system just needs a charge of refridgerant due to not having enough.
HEATER NOT
BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD,
COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
HEATER NOT
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
issue.
blowing cold?
For car running hot and overheating issues, I suggest to you go
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
issue.
blowing cold?
