since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element. Here are the 3 main faults to look for in your oven or cooker that is not heating
1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Most modern
gas ovens and many broilers use a "glow-bar" style of igniter that
glows red-hot to ignite the gas. If the igniter doesn't reach the
proper temperature, the gas valve won't open. You may need to replace
the igniter.
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
