1994 Volvo 960 Logo
Anonymous Posted on Jun 11, 2009
How to reset the raido - 1994 Volvo 960
Ryan Amontos
Level 2:
Scholar:
  • Expert 60 Answers
  • Posted on Jun 11, 2009
Ryan Amontos
Expert
Level 2:
Scholar:
Answers
60
Questions
0
Helped
27366
Points
216
There is a trick to the procedure. You have to turn the key to position 1 or the first stop on the ignition. Turn on the radio and wait between 2.0 to 3.0 hours for the radio to reset and ask for the code. From the owners manual. My 97 takes between 2:25 and 2.5 hours to reset. Every radio is different.
To enter the code:
After installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
During this waiting period:
the battery must be connected
the ignition key must be turned to position I
the unit must be turned on
Make sure the headlights are turned off to help prevent battery drain (please refer to page 2:6 for information on turning the headlights off). Enter the code again once this time has elapsed.
Ryan
  • jeff cant
    jeff cant Jan 13, 2014
    Hi Ryan thanks for advice but not working , thanks for help
1helpful
How do i uninstall circuit system in 05 buick centuryk circuit light blinks in raido car can not start
thats the anti theft and would be near impossable to remove , contact a dealer as there is most likely a way to reset the anti theft
Anti theif HOW TO RESET RAIDO
tiny reset button on the back of the face that ejects hope that helps
Reset security for 2002 mercuray cougar
There is no such thing as a reset. It either works correctly or you have aproblem and need the system scanned for faults.
2helpful
Regarding my 2009 Mitsubishi Lancer: Recently I took the radio out of my car and when I put it back in- It only functions when the headlight are on. Need to find the solution to fix it back to normal. Also...
befor you removed raido did you disable your anti theft if not then you need to have the anti theif reconfiged by a dealer, the reason it works with lights on is that its a over ride so if you raido gets theifted you will still be able to drive the car.
I have a 2003 Toyota Corolla with about 169000 miles ..the check engine light is coming on. I tested it with my mechanic and it seems to be a catalytic converter problem. The code comes up 420 I believe. I...
yes this is true if you unhook the battery cables and tuch them togather for 2 min
this will reset the computer make sure you have the code for your raido becouse
it will reset the raido to
once you reset the computer dont drive it very far take it rite down and get it inspected
be for it comes back on/// also it might not come back on at all but this will work
hope this helps you
good luck
bob
Have a CD stuck in the CD player, what is the best method for removal?
Hi
You can disconect the battery let it sit for 15 minn and then reconect the battery this will power down the raido ,, if the cd is not damaged or warped it will now eject, ,,,, If the cd is damaged you will need to remove the raido and have the cd removed by a raido tech the raido will need to be takiin apart.
Will resetting the anti theft reset the radio as well?
if the raidos are like the sunfires you will have to have the unlock code to reset the radio the dealership should be able to do it fairly cheap because they are all differant
3helpful
2answers
Reset pin code on raido
tuen radio off...hold #1 and #6 on preset buttons...tuen radio back on an alphanumeric number will display theere should be 8 digits and 2 numbers...you will need to call acura and give them these numbers and they should give you a lock code to enter hope this helps
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
