Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Anonymous
Level 3:
  • Belkin Master 6,487 Answers
  • Posted on Jun 11, 2009
Anonymous
Belkin Master
Level 3:
Answers
6487
Questions
6
Helped
1557333
Points
18452
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
3 Related Answers
Anonymous
  • 20 Answers
  • Posted on Oct 31, 2007
SOURCE: Belkin Wireless G Plus MIMO Security Problem
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Anonymous
  • 6487 Answers
  • Posted on May 09, 2008
SOURCE: Slow Internet using Belkin Wireles G Plus MIMO
Try setting the MTU size to 1400 and also check if there's any firmware update for it if there is update the firmware.
Hope it help
Anonymous
  • 4 Answers
  • Posted on Apr 02, 2009
SOURCE: need drivers for the belkin
I recently purchased a Belkin router and had to update the firmware. I called Belkin who directed me to their UK site. The firmware is downloadable from the site BUT depends on the version of the router (this is written underneath). It will say eg ver.5000, corresponding to version 5; or, ver.4000 for version 4. You have to download that which corresponds to your version. Try this:
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D7632uk4A&aid=6105&scid=314
1helpful
Hi, I need to find my password on my Belkin G Plus MIMO Router
Welcome to Fixya. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank.
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
If you have questions please let me know. Thanks for using Fixya.
Can a belkin network card f5d7050 work with a belkin g plus mimo router
As MIMO is compatible with all wireless g products there shouldn't be any issues at all....
so some questions:
  • do you have other wireless devices working with the router? if so can you duplicate their settings for this n/w card?
  • have you set security on the router?
  • what are you using to connect to the network the windows interface (assuming it's PC not MAC based) or the Belkin one?
i have a linksys g n/w card attached to my MIMO router & it's fine so I'm sure that this is solvable!
I have belkin g plus mimo router which states connected with limited or no connectivity help please
u are typing in the wrong wireless password. acsess the router by using the IP: 192.168.2.1 in the internet explorer and click security in the left side of router's set up page.
1helpful
I have wireless broadband with a Belkin ADL2+
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
How to you secure a belkin G + MIMO router
Click Here
Bought an Belkin wireless g plus mimo router at
You maybe able to reset the router to the factory default by powering up the router, press and hold the RESET button at the back of the router for 7 secs..
Then open a browser and type in the IP configuration address to reconfigure the router.
I cannot connect to internet with ps3 using belkin g plus mimo..
you might need to disconnect your modem for 30 secs then reconnect it . i have just reset my router and then the pc would show a connection but it only went to the router not through to the web.disconnect your modem reconnect then do a reconnect on the pc
2answers
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Belkin g plus mimo router
the PS3 connects to router via a crossover cable yes?
you may need to manualy set the PS3 as a trusted acception in the routers security system, (using either its MAC address, or its set IP address if u manually gave the PS3 one)
2answers
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
