The have install MIUI applications. But it took too much to be completed. So just cancelled it. after cancelling it, the screen shows no software applications, it appears as black. But it can answer incoming calls. and also the notifications that are s only shown above the screen..i.e battery,wi-fi, indications
SOURCE: black screen
Your ribbon that connects the motherboard to the lcd is broken you need to have it replaced.
SOURCE: All Incoming Calls Show As Private Number
First thing : the person who's calling you have CLIR . Don't put the same number to phone & SIM. Use the phone memory and also save numbers in international format.
SOURCE: the monitor was working fine,but for one night the
theo_christo, Get into my FIXYA profile and see if anything interests you or your BLACK or BLACK/BLANK screen symptom. Learn about the "flashlight" test that every "CCFL backlit lcd" monitor owner should know how to do and interpret the results of. 12fixlouie READ, READ, READ!
SOURCE: how do i answer an incoming call when the phone is
if you are saying that it is panel locked, just press the call key and it will be unlocked automatically once you received incoming call..
SOURCE: The screen on my samsung u900v is not working, it
The problem with your phone is that the flex on your phone screen is bad and will need to be replace.
All you need to do is just to change the flex of your phone screen and you will see that it will display.
Take care.
Testimonial: "excellent quick response"
