HI,
One way is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow on that box for a drop down list and choose something, like 90% (there is a custom option at the bottom of the list if you need to set something unique in between what's listed) and see how it changes the print size of what is to be printed out and choose the one that looks and works best for you without cutting off text somewhere. This will make it larger when printed out.
Another way that usually works to make the print larger when printing internet stuff & emails is by changing the view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Sometimes adjusting the current window's magnification (lower right corner of screen or Ctrl button + scroll wheel on mouse) can have an affect on print size.
The only other method is to copy & paste the text into a text editing software like Word and adjust the text size there. If you're using a text program, then you simply adjust the size of the text to a 12 or 14 point, or larger, font size (adjust depending on the font and size you need) and that should do the trick.
More info see this link.
https://www.inkling.com/read/photoshop-cs6-missing-manual-lesa-snider-1st/chapter-6/resizing-images
Thanks.
Technical Support
SOURCE: Yahoo email... I receive pictures with my emails
You can send it as an attachment. To do that compose your message like you normally would. Under the subject bar there is a link that says "attach files" with a paperclip next to that. Click on that and then a box will come up and you select your picture from there. You can attach up to 5 files. There is a box that says "browse". Click on browse and another box will pop up. This is where you find the file you want to add, click on it and it will attach it to your email. Best wishes.
SOURCE: I recently bought an HP Mini 210. When I read an
Good day,
Try adjusting your screen resolution by going to Control Panel/Display/Screen Resolution
