Is epson Stylus t10 compatible with any version of windows 7?
Yes. You may download the Epson driver from http://www.epson.com.sg/epson_singapore/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_T10
SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
SOURCE: compatible driver for epson stylus dx6050 using windows 7
Try downloading them from Microsoft's site. here is the link:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Epson%20Stylus%20DX6050%20All-in-One%20Printer&v=Epson&uid=C11C657022&pf=8&pi=4&c=Printers%20%26%20Scanners&sc=Multifunction&os=32-bit
You can also try downloading them from here:
http://www.bioticaindia.com/dx6050.html
Hope that will do the trick!
SOURCE: No Windows 7 driver for Epson Stylus Photo 785EPX printer
There is a driver--it's provided by the Microsoft website. While your computer is connected to the Internet, connect your 785EPX to your computer via USB and then turn the printer on. The driver will auto download and install. I just did this on an HP DV7 laptop and the printer works fine, showing ink levels, too, though you have to access the printer properties to see this.
