SOURCE: no road maps ( Zumo 550
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
SOURCE: SHUTDOWN
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
SOURCE: Garmin zumo 550 map update problem
SOURCE: map update notice screen
Resetting or trying to recalibrate the touchscreen does not work for this problem. Every time I try to reset or recalibrate, the Map Update Notice immediately pops up and I have not found a way to bypass this screen. I think this may be a glitch programmed by Garmin to force users to buy an upgrade after a couple of years.
