I lost the instructions for the alarm clock be fore i could set it up. we have put batteries in it but cant figure out how to insert the time, date, and set the alarm
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
Mode
Set
Scan
Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings. Set Year
Press Mode until the date appears.
Press Set. The year will begin to flash.
Press Mode until the correct year is reached.
Press Set.
Set Date
Press Mode until a date appears in the form of MM-DD.
Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
Press Mode until the correct month is reached.
Press Set. The day (DD format) will begin to flash.
Press Mode until the correct day is reached.
Press Set.
Set Time
Press Mode until the time displays.
Press Set. The hour will begin to flash.
Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
Press Set. The minutes will begin to flash.
Press Mode until the correct minute is reached.
Press Set button.
Set Alarm
Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
Sliding the selector to the far left will result in Barbie's voice as the alarm.
Sliding the selector to the far right will result in a piercing noise as the alarm.
Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Hopefully you've figured this out by now, but if not then I hope this helps.
Alarm Setting - Press Mode twice to change the alarm time. Set switches between hour and minutes and Adjust changes the time. The alarm is on when there is a symbol at the top right on the display. Press and hold Set then press Adjust to toggle the alarm on or off.
Time/Date Setting - Press Mode three times to change the current date/time. Use Set to move between the hour, minutes etc and Adjust to change them, as with the alarm.
Pressing Mode once accesses a stopwatch function. Adjust to start/stop and Set to clear.
I bought one of these for $3.00. I found it in the clearance sale aisle at my local Wal-Mart. The instructions refer to it as being an "Automobile Clock."
In the instructions, "M" refers to the "Mode" button, "S" refers to the "Set" button, and "D" refers to the "Date" button. These are the instructions that came my KATEC #38 travel alarm clock:
1. In normal mode, there will show hour, minute, second and week. Push "D" to show date and push "S" to show alarm-time.
2. Adjust alarm-time: Push "M" two times to enter into alarm mode. Push "S" to choose hour and minute. Push "D" to adjust the right time. Finally, push "M" to return.
3. Adjust real time: Push "M" three times to enter into adjust time mode. Push "S" to choose second, minute, hour, day, week, and month in order. Push "D" to adjust correspondence number for right volume. Finally, push "M" to return to norm-al mode.
4. Sport Function: Push "M" for one time into sport watch function mode. The beginning state is show as 0:00:00. Push "D" to enter into recording time. Push "D" again to stop. Push "S" to return to the beginning mode 0:00:00.
5. Adjust ON/OFF alarm mode. In normal state, push "S" and "D". You can choose alarm on or off. When alarm operates, the alarm symbol will be displayed on.
Moderately difficult, but not impossible. ;) I picked up this clock @ second hand store with no instructions and was able to figure it out how to set it in about 15 minutes. I liked the calendar feature on the face and the LCD (as opposed to LED because I prefer my bedroom dark when I sleep).
When setting this clock, one of the keys is to pay attention to the the icons displayed on the face toward the lower left. Default "MODE" is time set. To set the time: Press "SET" followed by either "HOUR" or "MIN" while the display is flashing to increment the hours and the minutes to the correct time. As previously state, the default "MODE" is time set.
Pressing "MODE" one time accesses a secondary clock that you might use if you regularly travel to another time zone (new icon w/ 2 clocks appears). Setting the secondary clock uses the same method above.
Pressing "MODE" a second time accesses the first alarm setting (alarm clock icon starts flashing). Same method to set.
Pressing "MODE" a third time accesses the secondary alarm setting (second alarm clock icon appears and begins flashing). Same method to set.
Pressing "MODE" a fourth time accesses a timer (hourglass icon appears). Same method to set.
Pressing "MODE" a fifth time allows you to set the calendar (calendar year appears where the digital clock display was). Press "SET" to change the date: "HOUR" increments the month; "MIN" increments the day; "MODE" increments the year. Press "SET" again to exit.
Pressing "MODE" a sixth time returns to the default time set mode.
I hope this helps someone! God's blessings in Jesus Christ! ~Thomas
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date:
"To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously."
Also
"LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer."
The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse.
Good luck.
